Do you always unplug your saw?
Forum topic by DavidTTU posted 07-15-2015 01:59 PM 2129 views 0 times favorited 68 replies Add to Favorites Watch
View DavidTTU's profile
DavidTTU
141 posts in 1660 days
07-15-2015 01:59 PM
Topic tags/keywords: plug tablesaw
First a story.
Last night I was working on a bookcase with a friend when a very strange thing happened. I was cutting dados in the side assemblies and flipped the saw on, made my cut, and went to flip the saw off but nothing happened. I felt the switch “Click” like it always does but it did not turn the saw off. I calmly went and unplugged the saw. I checked the switch, cleaned it out, made sure everything looked correct (and it did) and plugged the saw back in. As soon as I plugged it in, the saw kicked back on. The tablesaw is a Delta contractor 36-979. The switch is the basic stock Delta mechanical paddle switch. I ordered another switch last night and believe that will solve the problem.
The only part of this that really bothered me was thinking about how often I change tablesaw blades with the saw still plugged in (yep, let me have it). My train of thought is if I unplug every time I change a blade or a bit on a machine, I wont ever get anything done. And before, I had no reason to doubt my switch. Things changed last night.
I work in the outdoor industry and am very familiar with the term risk management. Obviously, unplugging the saw is the best practice. Before last night I knew there was a potential risk but it felt so insignificant that I felt comfortable not unplugging my saw during blade changes.
What I would like to know is your thoughts and what you personally do in your shop. I’d love to hear some personal stories so that I can make a more educated thought process.
-- -David -- Lubbock, TX
68 replies so far
View Murdock's profile
Murdock
128 posts in 2508 days
#1 posted 07-15-2015 02:09 PM
I always unplug my saw anytime I am changing blades or checking the angle on the blade.
I also unplug it when I am done for the day. Unplugging when I am done is more about not being surprised the next day than anything to do with thinking it will come on when I am out of the shop.
Not sure how often you are changing your blade, but I find it only takes a few extra seconds to unplug and it potentially saves fingers/hands…
-- "Anyone who has never made a mistake has never tried anything new." - Albert Einstein
View Richard H's profile
Richard H
489 posts in 1705 days
#2 posted 07-15-2015 02:13 PM
There is very good logic behind the lock out tag out rules in the industrial space for working on electrical machinery. They have evolved over the years not from paranoia but from a understanding of the risks involved in assuming something is in a certain state without confirming it is. I’m not sure I would ever trust anything short of a physical disconnect switch as like you experienced magnetic switches can and do fail. It’s also not that difficult to accidentally start a lot of switches with a good bump while you are digging around in the cabinet either. You might go your whole life and never experience a single issue but one incident could change your ability to woodwork forever. I’m not sure the 10 seconds it takes to unplug a tool is that big of a tradeoff.
I remember one time I left my dust collector with a wireless switch on by accident. I was woken up in the middle of the night by the sound of the thing turning on which was very discerning. I rushed down to the garage and powered it off to no ill effect but I had to wonder what would have happened if we had been gone on vacation and that happened? Since than I have been very religious about unplugging everything at the end of the day.
I have magnetic cord holders on all my power cords now and when I’m either done for the day or when I change a blade I will unplug it and stick the cord to the top of the tool to remind me it’s there. Also keeps me from stepping on them.
View Soonerdg's profile
Soonerdg
12 posts in 2410 days
#3 posted 07-15-2015 02:23 PM
Yes I unplug when I change blades. but the motor on my saw can be unplugged from the switch so it pretty convenient being right there on the saw.
-- "Life is a matter of luck and the odds of success are in no way enhanced by extreme caution." - Erich Tropp, German U-boat Commander, 1945
View DIYaholic's profile
DIYaholic
19623 posts in 2699 days
#4 posted 07-15-2015 02:29 PM
I always unplug the cord, for blade changes and adjustments….
& I can still count to 10….
View ChuckV's profile
ChuckV
3124 posts in 3552 days
#5 posted 07-15-2015 02:31 PM
I always unplug the saw before doing anything around the blade. I unplug other machines too whenever an accidental start would be dangerous. I got into this habit from a faulty switch on my Delta(!) drill press. Sometimes, it would not turn off. Then I would have to clean up the contacts on the switch. I have since replaced the switch with a paddle switch from Rockler.
To me, the unplugging is just a habit like buckling a seat belt in the car.
-- “Big man, pig man, ha ha, charade you are.” ― R. Waters
View Bill White's profile
Bill White
4948 posts in 3985 days
#6 posted 07-15-2015 02:37 PM
I’m in the “un plug” camp as well.
Woke up early one AM to hear the compressor running. WHAT? The pop off valve had a leak, stuck open, shop full of smoke from the compressor body running for unknown hours.
Luckily, no damage to the comp., but I installed a power switch to the wall plug, painted the on position red.
Changed out the pop off the same day.
Back to the table saw. No way am I gonna change a blade, etc. with that puppy plugged in.
Gremlins are everywhere. They love power tools.
I even unplug all tools when I travel.
Bill
-- bill@magraphics.us
4999 posts in 2518 days
#7 posted 07-15-2015 03:03 PM
Another to always unplug. To make this a little easier, my saw is on an extension that’s long enough to hang right on the front of the saw…I only have to reach below the table to unplug it. If you want to spend the money you can get on of the switches that allow lock out and just throw it (skip the lockout part). As for not doubting your swotch, this may not be the case with your saw, but a lot of the later model Uni’s have the magnetic switch. This switch has been known to engage with a good thump….which is one of the reasons I always unplugged mine.
View RobS888's profile
RobS888
2413 posts in 1869 days
#8 posted 07-15-2015 03:18 PM
I unplug as well and hang the cord on the fence handle.
-- I always suspected many gun nuts were afraid of something, just never thought popcorn was on the list.
View SirIrb's profile
SirIrb
1239 posts in 1255 days
#9 posted 07-15-2015 03:23 PM
What about you guys who have your saw hardwired? 3 ph is, I believe, or it can be. You flip the breaker?
View rwe2156's profile
rwe2156
2964 posts in 1505 days
#10 posted 07-15-2015 03:32 PM
Never turned it off for blade changes in 20 years never even thought about it.
Now you all got me thinking….....
View AHuxley's profile
AHuxley
663 posts in 3346 days
#11 posted 07-15-2015 04:03 PM
- SirIrb
Most of my machines are hardwired but they all have disconnects wired in. I use air conditioner disconnects, since they are required by code for A/C units almost everywhere they are easy to find and cheap. At $12-14 at most any big box they are significantly cheaper than a quality receptacle and socket (for 240v applications) and are easier to flip off and on than plugging and unplugging. Just get the ones that have a flip switch (they look like a breaker switch but the inexpensive ones don’t have over-current protection, which you don’t need) instead of the ones that have a pull out fuse holder.
AHuxley
#12 posted 07-15-2015 04:05 PM
- rwe2156
Reading this gave me the mental image of someone changing a TS blade with the saw running!
View Don Broussard's profile
Don Broussard
3570 posts in 2276 days
#13 posted 07-15-2015 04:08 PM
Another unplugged here. Every time I leave the shop, my tools are unplugged, and the cord draped over the tool. Definitely unplugged for blade changes.
-- People say I hammer like lightning. It's not that I'm fast -- it's that I never hit the same place twice!
View schnable's profile
schnable
24 posts in 2106 days
#14 posted 07-15-2015 04:37 PM
I unplug to change blades and hit the breaker at the end of the day.
Andrew
-- Andrew
View hotbyte's profile
hotbyte
991 posts in 3000 days
#15 posted 07-15-2015 04:42 PM
My previous Craftsman 113 saw was like this and I always unplugged at the switch for blade changes. New Delta saw is not like this and I’ve been unplugging about 1/2 the time. This has me thinking of adding an outlet box, mounted extension cord or something to saw and using for easy unplug when changing blade.
I have my router table setup with outlet box so I can easily unplug for bit changes.
- Soonerdg
showing 1 through 15 of 68 replies
