Trimming out an outside corner in three dimensions.
Forum topic by CB_Cohick posted 07-15-2015 01:48 PM 694 views 0 times favorited 12 replies Add to Favorites Watch
View CB_Cohick's profile
CB_Cohick
484 posts in 1251 days
07-15-2015 01:48 PM
Topic tags/keywords: question miter saw geometry trim
I messed around with this long enough to find a compound bevel that works. My question is why does it work? I want to know the logic behind why 33.9 degrees allows these pieces to come together. I understand the 45 degree piece of this compound bevel, and in my head I imagined somewhere near 40 degrees was the magic for the second angle. Then I noticed a mark for 33.9 degrees on my compound miter saw and gave it a shot. Well, butter my buns and call me a biscuit it worked. I want to understand why. Here is the moment of success.
-- Chris - Would work, but I'm too busy reading about woodwork.
12 replies so far
View Yonak's profile
Yonak
986 posts in 1521 days
#1 posted 07-15-2015 02:02 PM
Chris, you must understand the concept of compound angles because you figured an angle of about 40° would be about right for a good fitting joint. Clearly, 33.9° is the constant. Whether some wise person figured it out by trial and error or if they calculated it doesn’t matter .. What was your question again ?
CB_Cohick
#2 posted 07-15-2015 02:09 PM
- Yonak
What is the mathematical equation that gives the answer 33.9? Something like 3(2x+2y)(magic)=33.9
View rwe2156's profile
rwe2156
2926 posts in 1481 days
#3 posted 07-15-2015 04:00 PM
Compound angles just like cutting crown molding.
There is also a similar thing in chair making where the legs have two angles, the splay and the something else. Anyway, the combination is the “resultant” angle.
As far as the equation….
....Google it!!
View dhazelton's profile
dhazelton
2767 posts in 2297 days
#4 posted 07-15-2015 05:38 PM
That doesn’t look right – has an open birdsmouth.
I thought the 33.9 was for cutting standard crown when you tilt the blade. Spring angle and all that good stuff.
CB_Cohick
#5 posted 07-15-2015 05:45 PM
That doesn t look right – has an open birdsmouth.
- dhazelton
Yeah, I need to clean up the cut a bit, and hold it better. But it really does fit if you jiggle it around just right. I also thought the 33.9 was just for crown molding. Maybe 33.9 is merely close.
Yonak
#6 posted 07-15-2015 07:26 PM
- Chris
I think you got it.
View JoeinGa's profile
JoeinGa
7736 posts in 2007 days
#7 posted 07-15-2015 07:26 PM
- CB_Cohick
dhazelton
#8 posted 07-15-2015 09:48 PM
How did you hold the corner bead to the fence? Needs more ‘splainin.
Yonak
#9 posted 07-15-2015 10:08 PM
On the other hand, I don’t understand why each rail does not have two 45° cuts at right angles to each outside face.
dhazelton
#10 posted 07-16-2015 12:25 PM
I believe we’re talking one cut. 33.9 bevel at 33.9 miter? He hasn’t explained….
CB_Cohick
#11 posted 07-16-2015 12:34 PM
How did you hold the corner bead to the fence? Needs more splainin.
- dhazelton
Right you are. The corner bead is L shaped (90 degrees). I held one side of the L flat against the fence. The miter angle was set to 45 degrees, and the bevel angle was set to 33.9.
Yonak
#12 posted 07-16-2015 12:51 PM
I believe we re talking one cut. 33.9 bevel at 33.9 miter? He hasn t explained….
- dhazelton
Wouldn’t one cut leave a void in the middle with no way to attach ?
