Advice for checking new PM1000 for problems
Forum topic by GTIndEngr posted 07-15-2015 04:45 AM 620 views 0 times favorited 1 reply Add to Favorites Watch
View GTIndEngr's profile
GTIndEngr
4 posts in 1010 days
07-15-2015 04:45 AM
I’ve worked for years with my first saw, Ryobi BT3000. It was fine for what I needed, but I was starting to get serious, building some furniture and such as a fairly serious hobbyist. Thanks to these forums, i had some ideas what I wanted and was eyeing a Grizzly, when along comes a brand new, in-the-box PM1000 with the 52” rip FOR $1,200!!!
Someone bought it on Amazon and refused delivery when it arrived. It went to their returned goods warehouse where an auction house bought an entire lot of returned goods that included it. They offered it for $1,200 on EBay so I bought it (bonus, no sales tax!)
Turns out, it wasn’t just buyers remorse. The pallet it was screwed to was all busted up. Two cross members had broken so the saw was tilted in there and not entirely secured because one of the broken boards was the one it screwed to. Otherwise, original packaging. Metal bands intact around the thick cardboard boxes, and no signs of damage to the cardboard. My guess, it got set down hard or maybe a forklift hit the wood just right and busted it up.
It is all unpacked now, and looks great. Only sign of damage is scratched paint at the bottom from rubbing where a nail was left protruding after a board broke apart.
$64,000 question: aside from normal first time setup, is there anything you recommend that I check to confirm that there is no serious damage from the rough handling?
1 reply so far
View jonah's profile
jonah
1655 posts in 3261 days
#1 posted 07-15-2015 11:46 AM
Tricky situation. You’ve basically got no warranty to speak of (aside from eBay’s purchase protection), so you’re in the proverbial lurch if anything goes wrong. Check everything. Go step by step in the assembly section of the manual, and every time you interact with any kind of a part, check it for damage, flatness/roundness/straightness.
Make sure all the sheet metal that makes up the base is straight and that the corners fit properly.
The base needs to be solid and to hold the heavy parts of the saw securely.
Be sure the trunnions are undamaged and operate normally.
The table, obviously, needs to be flat.
The motor needs to start, run, and stop smoothly.
The fence rails need to be straight and flat.
The fence needs to slide, lock, and operate normally.
The arbor needs to rotate without wobbling.
