I need help
« back to LumberJocks.com Site Feedback forum
Forum topic by jockmike2 posted 48 days ago 375 views 0 times favorited 22 replies Add to Favorites Watch
View jockmike2's profile
7356 posts in 1145 days
48 days ago
Topic tags/keywords: question
I put about 5 coats of shellac on an outdoor bench not realizing the sun would make it blister. Could I now put several coats of Spar Varnish over that without making a mess of things. In other words after the varnish could I then set it outside without it blistering? Thanks, mike
-- Mike. mwurm13@yahoo.com
View notottoman's profile
notottoman
487 posts in 129 days
48 days ago
Hey Mike Has it already blisterd by being in the sun?
-- "Even small steps makes a distance." (Shawn Phillips, musician)
48 days ago
Yup noto, but I’ve already sanded it down and got the pits out.
Dick, & Barb Cain
7046 posts in 1198 days
48 days ago
What kind of wood is it. Maybe it’s sealed to good, & if the wood still has moisture in causing the
blisters. Maybe you should try an UV resistant oil finish.
notottoman
48 days ago
Give it another coat or two of shelac to close the holes, and varnish when dry.
Should do the trick.
Try to let the first coat of varnish set without the sun. Keep it in a drafty place to speed things up. D&B C have a point too.
Make sure each coat of the shelac is dry as well
25811 posts in 1299 days
48 days ago
It sounds to me that you are trying to put a coat of varnish on top of a defective (non holding) finish. I don’t think that it will work out.
But what do I know. Can you do the same thing on a wood sample and find out.
48 days ago
The wood should be dry. It’s a hunk of slab wood I got from the sawyer 2 winters ago. I’ts been in the garage for at least 2 years before I put the shellac on it. I didn’t put anything on under the shellac, just sanded it smooth. Then left it in the sun to dry. Next day it blistered all over where the sun hit it. I just finished cleaning the back down to the bare oak and re-sprayed it with spar varnish about 5 coats. Too labor intensive. I was hoping I could just put a couple coats of Spar on the seat and call it good. What do you think. I sanded the pits out of it but it still has shellac on it. So you are saying Shellac should not blister in the sun?
View mski's profile
mski
363 posts in 879 days
48 days ago
My 2 cents, is if Shellac is blistering you still have moisture in the wood.
So spar varnish will blister too, only a bigger headach to fix.
2 years air drying may not be enough for a thick slab of oak, I think they say a year an inch for air dry.
-- MARK IN BOB, So. CAL
48 days ago
Wow, thanks for that tidbit. If only you had told me sooner. LOL. Thanks very much for the info. Yea it’s a pretty thick piece of oak. Well back to the stripping. So all that work on the back rest was for naught? Bummer.
notottoman
48 days ago
I personally think that you have applied too many coats of shelac without letting each coat dry completly!
This is important as shelac is a resin and needs to seal. Applying a coat before one coat has dried defeats the object and you will have blistering. Just like adding a coat of polyeurathane to an undried coat of poly…
Ps I’m not dissagreeing with these comments. ;-)
48 days ago
Ya, that’s it. That’s the ticket. I’ll just wait a few months for it to dry. Then try it again. I love you noto. You make my life so much easier. LOL.
17138 posts in 476 days
48 days ago
Hey Mike Shellac is one of the one finises that has the least resistant to water It could be as others have suggested that the wood is not dry or it was to moist. Shellac will redisolve with a spray of denatured alcohol or more coats of shellac. I would re coat with on of those and set it inside if you don’t have problems then it was the outside conditions if you do have problems it’s that the woods to wet. The great thing is that shellac will let anything bond to it so you can spar varnish after the moister problem is addressed
48 days ago
One other option is that your shellac has gone bad it does not have a real long shelf life. You might apply some to a dry scrap of wood and see if it does the same thing.
48 days ago
Thanks Jim, I really may have put coats of shellac on wet coats. I just can’t believe that wood was wet. It laid aside my woodstove all last winter. That should have sucked all the moisture out of it. But, then again. I did put alcohol on it and stripped some of it off, and sanded it down smooth. Maybe I’ll wait till spring and see what it does. Or set it out in the sun right now and see if it still blisters. So shellac, in itself, should not blister from being in the sun?
View Tony's profile
Tony
813 posts in 929 days
48 days ago
Hi Mike.
I would get the bench back inside for the winter, as has been already stated that slab may not be dry enough. Can you post a picture of the bench so we can see the thickness of the lumber used in the bench and possibly the extent of the blistering.
Is the blistering all over the bench or just on the slab?
Is the blistering only where the sun has had direct contact with the bench, or is all over, including under the seat?
It is said, a year for each inch of wood for it to air dry – that is a very general rule of thumb – I would say that if the oak was cut in the spring, then you may have to allow 2+ years per inch (full of sap), even then, that will probably only dry to 15% or so, which is ideal for outdoor use – for fine furniture use you need about 6 to 8% and the only way to achieve that is to have the wood in a controlled environment with a RH of about 35 – 45% and a temperature of about 68° F (20°C) with this dry warm air moving across the face of the wood constantly.
Personally I would not use shellac on an outdoor project, not even as a sealing finish- it is not a finish that will withstand the elements or abuse that outdoor furniture will receive.
Just think – if you apply the varnish on top of the shellac, then the varnish is only bonding to the shellac, not the wood, so the slightest lifting of the shellac and the varnish comes away.
Ideally you want a deep penetrating sealer – if you decide to go with varnish, then you should apply one or two coats of varnish thinned with 40 – 50% mineral spirit (this will penetrate the wood very deeply, then you can start the process of apply the full strength varnish on top of the diluted varnish, this will cause a very strong, deep bond between the wood and the finish. In the end grain, especially the legs, where it comes into contact with the ground, I would soak these in the diluted varnish for at least an hour and leave the project for a week or two (depending upon conditions) to dry and slightly harden before continuing the process.
As for cleaning the shellac off – you have done most of the work, sanded and applied alcohol to clean the wood, but go over the whole project again, checking especially at the joints that the is NO sign of any shellac left ( not forgetting that Oak is an open grained wood, so the shellac may have gone deeper than you imagined) if there is this will be a week point in the finish.
I hope this helps you a Little in deciding
48 days ago
It helps a great deal Tony in deciding what I’m going to do. I just stuck the seat portion out in the sun to see what would happen. I have that almost completely stripped of shellac. The back of the bench I have already stripped completely and started spraying with a mixture of BLO, mineral spirits and varnish. As I continued adding coats I just used spar varnish for the last two coats. After looking the bottom part over, I took them apart, I nearly have that stripped of shellac, so I’m going to go ahead and finish. Then start the same process as I did on the back. It’s about an inch and a quarter thick, with the legs being almost 1 3/4 inches. What do you think of the process I did on the back? Is that going to work or should I just let them be until spring. Thanks for the advice all and to you Tony.
View GMman 's profile
GMman
1370 posts in 596 days
47 days ago
Sorry Mike unable to help.
-- --<<<<<< I will not stop until I get it right. >>>>>>--
View mski's profile
mski
46 days ago
Mike,
Been out of town but a late added note,
What seems dry and actually seems too dry could be very wet.
A SLAB (2+ inches) of wood will be so dry on the outside that it is cracking, one would think it’s ready, but in reality the center is no where near dry, and that moisture will go one way, out under your finish, that is why Anchor seal or the like is appiled to drying wood ,it lets the inside dry while keeping the outer from splitting.
Keeps the outer part of the wood from getting too dry while the center SLOWLY dries. Research the turning woods and they have alot of info on green wood curing.
46 days ago
Thanks Mark, yea I think I will wait till spring to finish it.
Dick, & Barb Cain
46 days ago
A good idea Mike,
You better keep it warm, & cozy behind the old Heatrola. LOL
2459 posts in 240 days
46 days ago
working in cabinet shops ,
we would spray lacquer outside sometimes ,
if the sun was hot , or we left the doors to long while we got the spray gun ready ,
it would blister .
the doors would release the heat inside the lacquer to fast ,
and it would blister .
only spraying when it was cool or inside out of the sun ,
let it work together .
View Tony's profile
Tony
45 days ago
Hi Mike
It sound like you have done most of the back breaking work – try and borrow a moisture meter if you are uncertain about the MC of the wood, but I think it will be more than dry enough by now – when you said a SLAB, I was think of a 3” or 4” piece of wood.
Leaving the unprotected bench inside the dry workshop will not harm it doe the next few months, just cover it to protect the wood from any splashes or spills – I would aim to start the finishing process about 4 weeks before you want to use it is out side – giving the varnish time to harden (it will be dry after a couple of days).
Good luck – Tony
View mynoblebear's profile
mynoblebear
71 posts in 6 days
3 days ago
Mike if there is a serious moisture problem what you will sea on the wood side is a milky appearance from the moisture trying to escape through the finish weather it blisters or not. The blistering could be from to thick of a sealer coat. A moisture meter will solve that mystery however I would recommend a penetrating finish such as one third turpentine one third linseed oil and one third a marine grade polyurethane. this will give it some protection and you can enjoy it for all of the years that it needs to cure being it takes one year per inch in thickness to cure.
-- Best Regards With, Personalized Rocking Chair, and, Chairs, On My Mind, http://mynoblebear.com
