So, I want to make an 1/2 oval shape base for a 1/2 oval shape top.
Forum topic by mahdee posted 07-15-2015 12:09 AM 847 views 0 times favorited 16 replies Add to Favorites Watch
View mahdee's profile
mahdee
3883 posts in 1764 days
07-15-2015 12:09 AM
Topic tags/keywords: question
Hi,
In doing so, how do I determine the angle of vertical boards that make the base?
I am assuming to do that, I can’t just use a string and two nails to draw the oval. As far as the angle cuts, I am clueless at this point. Any ideas?
Thanks
-- earthartandfoods.com
16 replies so far
View distrbd's profile
distrbd
2252 posts in 2443 days
#1 posted 07-15-2015 01:25 AM
Maybe this video will help?:
https://www.youtube.com/watch?v=J48e1mVQ_Sg
-- Ken from Ontario, Canada
mahdee
#2 posted 07-15-2015 01:35 AM
Thanks Ken. That will be a good reference for cutting the top. I thought I should make the base first. It is going to be made with vertical 2×4 or 2×6’s. In doing so, I have to figure out the angle cuts that follow the half eclipse. Very much like a whisky barrel sitting on its end. So, there may be a 15 degrees cut on both sides to create the curve for example. I wasn’t sure if there was a math formula that could figure the angle based on the X or Y axis.
View DIYaholic's profile
DIYaholic
19620 posts in 2672 days
#3 posted 07-15-2015 02:05 AM
Since the ellipse is not a circle…
I think all the angles would be different.
Yeah…. the calculus, that I can’t remember comes into play, I’m sure.
I would think a line, perpendicular….
to the slope of the varying curve….
would give you each angle.
That’s the best I can come up with….
Now my head hurts!!!
mahdee
#4 posted 07-15-2015 10:39 AM
Thanks Randy. I think that might be the best bet. Cut the curve on a piece of cardboard, measure 4” increments and connect them to the center, place the boards on top and mark the lines inside and out.
TopamaxSurvivor
18269 posts in 3673 days
#5 posted 07-19-2015 06:51 AM
It should be easy to do with the trig function tangent if you know how big both the top and bottom will be and the height.
mahdee
#6 posted 07-19-2015 02:51 PM
Thanks Bob,
Assuming the top and bottom are 3’ wide and height is 32” How would the formula gets plugged-in?
distrbd
#7 posted 07-19-2015 03:27 PM
- mrjinx007
This the simplest way imho.I would try it first, the more complicated ways gives me a headache.
mahdee
#8 posted 07-19-2015 04:01 PM
I know Ken.. I think that is the way to go as well. Nevertheless, I like to see the formula as well. So many things can go wrong when I comes to wood and precise measurements.
TopamaxSurvivor
#9 posted 07-19-2015 06:24 PM
Thanks Bob,
Assuming the top and bottom are 3 wide and height is 32” How would the formula gets plugged-in?
- mrjinx007
Maybe I don’t understand what you are trying to do? I envisioned a half an old fashioned coal bucket shape with the base and top being 2 different lengths and widths.
mahdee
#10 posted 07-19-2015 08:01 PM
No sir, both top and bottom would be same size and shape and the “wall” would be flush with the edges of top and bottom.
TopamaxSurvivor
#11 posted 07-19-2015 11:56 PM
so you want the intersecting angles of the boards that will make up the vertical sides. Sorry about the false hope. I probably could have figured those varying angles on the edge of the ellipse 45 years ago when I was a math wiz ;-) but that is beyond me now;-(
View ChuckV's profile
ChuckV
3118 posts in 3524 days
#12 posted 07-20-2015 12:33 AM
Determining the angles for just a quarter of the ellipse is enough. So, I would probably draw it out and use a bevel gauge to get the angles.
-- “Big man, pig man, ha ha, charade you are.” ― R. Waters
View jerryminer's profile
jerryminer
923 posts in 1438 days
#13 posted 07-20-2015 12:40 AM
Formula? Ellipses can vary so much and the size of the “sides” can vary, too, so a formula would be quite complex, with variables for length/width/number of facets/side width/thickness …
But if you draw it out full-size, you can take off the angles. Here is one example with approximate 4” sides:
TopamaxSurvivor
#14 posted 07-20-2015 12:43 AM
Depending on how critical the fit needs to be the individual pieces will need to be custom coopered, then each angle custom fit. This could get quite tedious.
mahdee
#15 posted 07-20-2015 01:54 AM
jerryminer, yes. It is too complex for a woodworking project and I should have known that before conceiving such a project. Bob, I totally agree. I think the beast course of action is to make the base and worry about the surface last. I went ahead and deviated from my original thought and am going to use a natural edge table to incorporate what
I had in mind originally. Next project, if this one is successful will be a stump. It is going to take me at least 4 months to figure this one out. I have already spent the last two weeks so far to get the natural edge at a 45 degrees using a sassafras board 3” thick. Thank you for all the input.
