Which sander should I buy?
Forum topic by friesenlips posted 44 days ago 285 views 0 times favorited 6 replies Add to Favorites Watch
View friesenlips's profile
friesenlips
60 posts in 315 days
44 days ago
I am going to buy a sander during the up coming tool show in my city in november but I can’t decide which one to buy. It will be used mainly for sanding cabinet doors for the kitchens that I build. The first option is a sander made by stockroom supply named the flatmaster http://www.stockroomsupply.com/Flat_Master.php I saw it in action last year at the tool show and it seemed to do a nice job. Second is the general international 15-250m1 double drum sander http://www.general.ca/site_general/g_produits/sander/15-250.html I know the general is an excellent sander and will do a great job. The flatmaster is less than half the cost of the general and I am told that the sandpaper will last a really long time on it so the costs for the paper will be less. Also the flatmaster is virtually dustless because all the sanding dust when it comes off the drum falls to the bottom of the machine. The general I can sand 2 grits at once, it has a conveyor belt where as the flatmaster I have to push the door through and the it seems I am getting more for my money with the general. How long does sandpaper seem to last on a double drum? I would probably use 100 or 120 on the first drum and 150 on the second. I have never used one before and do all my current sanding with a 5” orbital. Either of these will be a nice step up from a little orbital sander but in your opinion which one should I buy? Money is a little tight now but I want something that will last a long time because sanding is not one of my favorite things, haha.
View Lenny's profile
Lenny
126 posts in 421 days
44 days ago
Hi,
Machines of this size are well out of my league and therefore I don’t know much, if anything, about them. That said, you commented: “The flatmaster is less than half the cost of the general…” but I noticed at their site that you have to buy a motor. Seems to me you will definitely have to take into consideration the cost of the motor, the time to connect it, etc. Good luck with your decision. You sure do some beautiful cabinetry.
A woodworker who doesn’t like sanding? Wow, that’s rare! LOL
-- And on the eighth day God was back in His woodworking shop!
20629 posts in 716 days
43 days ago
I have a wide belt sander on my list and am going to go with a dual drum sander. It is more expensive but the ability to run two grits at the same time is worth the extra expense in my opinion.
7623 posts in 1112 days
43 days ago
I think you are right about getting more for your money with the big machine.
I can’t believe small drum sanders are so expensive. I see posts where guys have built their own for under $100, so it seems like some manufacturer could turn one out in the $200 – $300 range. I look at machines like the Sand Flee, and I just can’t figure out what makes it worth $750!
View Whitey's profile
Whitey
13 posts in 48 days
43 days ago
I use a performax 16-32 which is a single drum and where I use it for abrasive planing also its better than the double . I use perormax or sandbox brand paper at about$85 a box which will make 16 changes on the 16-32. I use 60, 80 and 120 grit anything finer plugs to fast. Just remember you need a very powerful dust collecter to use it ,when planing I can fill a garbage can with dust in 3 hrs.
-- You don't have to be crazy to work with juniper, but it sure helps.
View Dusty56's profile
Dusty56
3460 posts in 582 days
43 days ago
A lot of the guys here have made their own and saved a lot of money by doing so. If I hadn’t already bought my drum sander , that is the route that I would take.
The flatmaster really doesn’t appear to be any bargain if you consider having to buy everything that doesn’t come with it.
I didn’t see any price listed on the General link that you provided , but it appears to be a professional shop grade machine versus a homeowners / hobbiest unit. Do you have 220V available and a really good dust collector ?
friesenlips
43 days ago
Hi guys,
the only reason I am considering the flatmaster is because they offer a pretty good discount on it at the tool show. I would have to buy a motor for it and it would probably come to around $950 cnd. The flatmaster I would buy would be the 30” model vs the 24” which the general is. The general I think I could get for around the $1900-$2000 cnd mark since I just bought a 20” general helical planer and a general spray booth from the guys I would be buying it from. Hopefully they would give me deal, lol. I have a 3hp dual bag dust collector that should get the job done but need to upgrade it down the road and I do have 220 in the shop.
