wood filler
« back to Coffee Lounge forum
Forum topic by Pabs posted 47 days ago 289 views 0 times favorited 11 replies Add to Favorites Watch
View Pabs's profile
Pabs
50 posts in 351 days
47 days ago
hey all
need to fill some holes.. .about 3./4 inch diameter and 1/2 deep..
what’s the best stuff to plug this holes with?
I will be painting after… I just want to use something that can be sanded flush with the wood before I paint
thanks
-- Pabs
View interpim's profile (online now)
interpim
451 posts in 355 days
47 days ago
wood plugs
-- San Diego, CA US Navy
View GMman 's profile
GMman
1371 posts in 594 days
47 days ago
Depends what it is wall board, hard wood, and paneling.
About is what 3/4 less or more?
-- --<<<<<< I will not stop until I get it right. >>>>>>--
View UnionLabel's profile
UnionLabel
149 posts in 97 days
47 days ago
50 cal. holes?????
-- Easy Peasy Lemon Squeezy-May all your dovetails fit tight and right the first time
View Pabs's profile
Pabs
47 days ago
it’s on a door frame…Douglass fir..and the holes are irregular and in an odd spot..making it hard to use plugs
-- Pabs
View Jerry's profile
Jerry
60 posts in 50 days
47 days ago
This stuff is “Da Bomb” for “Paint Grade” stuff. Does not shrink (actually expands slightly), controllable dry times, non toxic, sand able, tintable, stainable, and accepts primer and paint like a sponge. I love it, its cheap too :)
Durham Water Putty
Durham Water Putty
An excerpt from their website;
”Remember, DURHAM’S is meant to fill voids.”
-- Jerry, "Some people are like Slinkies, They aren't good for much of anything, but they put a grin on your face when you push them down a flight of stairs"
7666 posts in 1115 days
47 days ago
Jerry is right on!
interpim
47 days ago
you could also route out a regular sized area and fill the hole with wooden plugs… Being 3/4 of an inch I would hesitate to use fillers.
16979 posts in 474 days
47 days ago
Water putty or body filler for paint grade
View Pabs's profile
Pabs
47 days ago
that looks like the product I need!!
but not sure they sell ths in my area (I’m in Moncton NB, Canada). I’ve never noticed that product before. checked the Home Depot site and they don’t have it there (online at least)
where doyou guys normally buy this stuff?
-- Pabs
25803 posts in 1297 days
47 days ago
Bondo: In the automotive section of Walmart or in the finishing dept of Lowes and HD.
Best stuff going.
Jerry
60 posts in 50 days
46 days ago
A note on automotive fillers in woodworking. If you go this route, try to find the “Lightweight” body filler. You will find that even the lightweight body filler is harder than the surrounding wood and you can easily create a “Scallop” around the patch if you don’t use a backer with your sandpaper. It also absorbs paint and primer differently than wood, enough so that it will show up in the finished product as a “Shiny Spot” unless sealed properly. Bondo, unlike “Water Putty” was not formulated to fill “Voids” , if you do decide to try to fill a big hole with it apply it in 2 or 3 applications instead of one big glob. Prep surface with 80 grit to give patch material a “tooth” to adhere to. Leave patch “proud” of hole and file or sanding flush before it hardens completely will give you better results.
In my experience the Durhams Water Putty much more closely replicates the porosity and hardness of wood eliminating these issues found with auto body fillers. Body fillers were made to be used with steel and the manufacturers try to model its properties more closely to metal than wood. Using an automotive grade “Primer Sealer” over the regular “Primer” helps hide these flaws. I have had very good results with the SEM product line. You can purchase these professional grade primer sealers at any auto body supply store. Your mileage may vary! YMMV
Jerry
