why don't more router tables use self squaring fence
Forum topic by TheSerpenteer posted 49 days ago 348 views 0 times favorited 9 replies Add to Favorites Watch
View TheSerpenteer's profile
TheSerpenteer
9 posts in 433 days
49 days ago
Looking at upgrading my router table from a benchtop that I’ve outgrown quickly to a nice standing table. I’ve narrowed it down to the Kreg table and the Pinnacle/Woodpecker table. The Pinnacle table has a little more work surface, but isn’t reinforced underneath, which leads to bowing concern, and it has a more traditional fence.
The Kreg table is steel reinforced underneath and has what I think is a super feature in the self squaring fence. I’m leaning toward the Kreg, would there be any cons to that self squaring fence that I’m not aware of. It makes me wonder why it isn’t a feature found elsewhere.
View Julian's profile
Julian
695 posts in 424 days
49 days ago
You don’t need the fence to be square to anything with a router table. You could have one side fixed on a pivot and it would work just as well.
-- Julian, Park Forest, IL
View miles125's profile
miles125
1442 posts in 904 days
49 days ago
Build you a table!
View SEE's profile
SEE
62 posts in 66 days
49 days ago
Ditto on building your own table. It’s a fun project and if well planned, you can get all of the features that you want for considerably less money.
Julian is correct, no need to worry about the fence being square to the table with a router table. There’s only one place that matters, the distance from the bit to the fence. Seems that it took me forever to get that to make sense in my head!
-- Build for the joy of it!
View UnionLabel's profile
UnionLabel
150 posts in 99 days
49 days ago
Try routing with a pin and bearing bit only and see what they mean about the fence.
-- Easy Peasy Lemon Squeezy-May all your dovetails fit tight and right the first time
View lowdrive's profile
lowdrive
3 posts in 262 days
48 days ago
You might want to check the Kreg again. I was pretty high on that one from what I had read and watched on the videos. But, Woodcraft had one on display, and my eyeball said it wasn’t square. I happened to have a tape measure in my pocket to check it with. It was not square. I tried changing it a couple of times and it was not squaring up on it’s own. From that point on, I figured that if I would need to measure each end to make it square, I would look at the fence system with the ruler on both ends.
View sh2005's profile
sh2005
41 posts in 135 days
47 days ago
By squareness, I am guessing you are talking about the fence being squared to the table top, miter slot or the edge of the router plate. In table saw, the fence squaring matters because the fence has to be parallel to blade and that’s quite a bit of distance. Typically, it’s about 7 inches when the bladed raised to its maximum height. So, essentially, there are two reference points when checking the distance of the fence from the blade : the front end and back end of the saw blade.
In the case of a router table, there is really one reference point: the router bit. To be more precise: the axis of rotation of the bit. As long as the fence is straight, the only critical dimension you need to take into consideration is the distance between the bit and the fence.
Kreg tables are nice, but they are not cheap either. As others have mentioned, you can build your own table for less, without really sacrificing anything. If you like Kreg’s fence system, you can add it to the table. But, if cost is not an issue and you want a ready-made table, the Kreg table will be a good choice.
View TheDane's profile
TheDane
209 posts in 562 days
47 days ago
There is at least one scenario where the router table fence needs to be 90-degrees square to the table top.
That would be when you are using a vertical panel-raiser.
Seems it would also be a good idea if you are routing a groove in the edge of a board.
If I had space in my shop, I would have a Kreg. Their stuff is top drawer.
-- The only place success comes before work is in the dictionary. -- Vincent T. Lombardi
View interpim's profile
interpim
457 posts in 357 days
47 days ago
I think a lot of people here are getting two different thoughts twisted here at once and I am getting confused, so I am sure there are others as well.
one thought being square to the table as in perpendicular to the table edge. And the other as square to the table face, or the L shape between the table top and the router fence.
The L shape between the top and fence is the only one in any situation that matters. The table edge in relation to the fence or bit is relative. All router bits can be approached from any side and they will still cut the same profile regardless. The fence on a router table is used as a guide and as some people have mentioned isn’t always necessary considering pins are used with bearing bits by lots of folks.
-- San Diego, CA US Navy
View BTKS's profile
BTKS
492 posts in 363 days
47 days ago
Self squaring fence sounds like a sales gimmick to me. Don’t know what one is but sounds like I don’t need it. I do however, really like Kreg products in general. As stated above, they are top drawer. Just my .02, BTKS
