bamboo plywood?
Forum topic by scottishrose posted 47 days ago 354 views 1 time favorited 6 replies Add to Favorites Watch
View scottishrose's profile
scottishrose
84 posts in 62 days
47 days ago
Has any one heard of bamboo plywood? I was searching the web for good prices on hardwood vaneer plywood and just came up on a mention about bamboo plywood. As I surmised by the small amount of info given is that the core is bamboo, with hardwood vaneer. I have not seen any source for it, but considering the popularity these days of bamboo flooring, it seems like a possiblity for a great new product.
Bamboo grows very fast, and once planted, you never have to replant. When you cut it down it just regrows a new shoot in place of the one that got cut. Some bamboo grows 40’ high in just a couple of years, which compared to growing fir or pine is quite prolific to say the least. Not only that, bamboo is very strong. I saw a picture of a cathedral built completely out of bamboo with vaulted ceiling and all by some artist. It wasn’t a real – permanent structure cathedral- just for an exhibition, but never the less was quite impressive since bamboo is not in most westerners architectural, building vocabulary. But could be coming to a home center near you. Any thoughts or more information?
View PurpLev's profile
PurpLev
2759 posts in 544 days
47 days ago
great product, very stable, very durable, very $$$$$ – I can only assume that you pay for the milling and processing of the material as this is probably the most green material on the planet (regrows, replanishes itself – even too fast and too much). also very hard on blades.
I based a project on bamboo plywood, but after calculating the material involved, the project was cancelled.
here’s a good site:
http://www.plyboo.com/index.php
scottishrose
84 posts in 62 days
47 days ago
Thanks for the link
from the look of things – it’s not widely produced or distributed – at least to the public at this time, except in flooring products. Since there is a bamboo for almost every climate the problem of exporting it from China, Japan or Korea, seems to grow it here. That would make it cheaper and more accessable. The people who distribute it have one plant in SF, so it is not so plentiful in the US at this time. I was mistaken though, As I thought they were using bamboo as the center with native hardwoods as a veneer. This is not true. I did see one product, however I think if it becomes popular in the next 10-15 years it will become the next version of basement plywood paneling.
View JimKing201's profile
JimKing201
33 posts in 464 days
46 days ago
Keep in mind that bamboo is a grass. Not a tree stem.
This may help solve/explain some of the slight, yet unusual properties of the cutting, milling, gluing, etc.. of bamboo.
-- Got Wood?
Beginningwoodworker
4187 posts in 569 days
46 days ago
Yes I have heard of it but it cost dollars! Great product.
-- CJIII Future cabinetmaker
View bendisplays's profile
bendisplays
39 posts in 296 days
46 days ago
Bamboo is becoming much more popular but it is very expensive. As plywood goes it is probably one of the most expensive plywoods out there. I believe the cost was around $145.00 per sheet for 1/2”. (this was a couple of years ago) Here is a source for bamboo plywoods:
http://bamboohardwoods.com/
I had a large retail display case project and was considering importing the wood from the philippines where it was really inexpenisive on a comparitive basis. By the customers choice we ended up using another plywood.
Ben
scottishrose
84 posts in 62 days
46 days ago
I have found that in regular veneer plywood that there is little difference in cost between 1/2 and 3/4”, but a marked difference between 1/4” and 1/2”. I was just fishing around on the internet trying to find the best price on Cherry veneer plywood when I saw the bamboo thingy, but not much info. I think we will be seeing more of it in the future as more production and growing moves to the US. As long as they take measures to keep it under control where they are growing it, and not cause an ecological disaster in our native woods I don’t see a problem growing it here as it has been used in landscaping for years. It is drought tolorant and fast growning and does not use a formaltihyde in the production, although from what I understand the high cost comes somewhat from the intense processing it goes through to become plywood or hardwood flooring.
Then again we are seeing quite a lot of new wood come on the market that was traditionally not used before. I know that where I live alder was always considered something for the slash burn pile. Now they are using it for furniture. I always wondered why as a young person – as it is a hardwood. My grandfather just called it junk. I don’t think much big leaf maple which grows here got used back then but is in demand now.
