Why did I buy these bandsaw blades?!
Forum topic by ForestGrl posted 07-13-2015 02:35 AM 1125 views 0 times favorited 10 replies Add to Favorites Watch
View ForestGrl's profile
ForestGrl
450 posts in 1050 days
07-13-2015 02:35 AM
This is kind of a reverse engineering question. Going through my stack of bandsaw blades today, most of them rusty :-( I found 3 unopened envelopes with Starrett Flexback blades in them: 1/4” x 105”, 4 TPI, skip-tooth .025 kerf. Obviously, I was anticipating a particular project for them, but it seems like an odd configuration. Thin kerf, sort-of-low TPI, but narrow blade. What in the world would I cut with this? I’ve forgotten pretty much all I knew about bandsaw blades, but I do know I need some new ones, so if these are dispensable, I’ll sell them.
-- My mother said that anyone learning to cook needed a large dog to eat the mistakes. As a sculptor of wood I have always tried to keep a fireplace. (Norman Ridenour)
10 replies so far
View bigblockyeti's profile
bigblockyeti
5090 posts in 1684 days
#1 posted 07-13-2015 03:07 AM
Thick stock and tight radius curves would be perfect for that combination.
ForestGrl
#2 posted 07-13-2015 03:25 AM
- bigblockyeti
Wish that rang a bell. I had a couple of production projects that involved thin stock and tight curves, but nothing that I remember with thicker stock. Hmmmm, perhaps the Tole-painting ladies that wanted unfinished stuff for their classes? That must be it! (didn’t work out, LOL) Whadya think, should I save them for smaller bowl blanks? I’ll look up the radius minimum on Suffolk Machinery’s website.
View higtron's profile
higtron
235 posts in 2641 days
#3 posted 07-13-2015 04:56 AM
They would be good for band saw boxes.
-- A friend will help you move, a good friend will help you move a body
View Jim Jakosh's profile
Jim Jakosh
20280 posts in 3069 days
#4 posted 07-13-2015 11:55 AM
The rule of thumb for bandsawing st 3 teeth per thickness of what you are cutting. So a 4 tpi should be used for 3/4 and thicker stock!!
Cheers, Jim
View Nubsnstubs's profile
Nubsnstubs
1279 posts in 1694 days
#5 posted 07-13-2015 01:48 PM
Forestgrl, you bought them for cutting turning blanks. You are a turner, aren’t you?
If I could get 3 tpi on 1/4” blades, that’s what I’d be using.That’s the same length my saw uses, and I seem to get better cuts with the 1/4” than the 1/2”............ Jerry (in Tucson) .
View MrRon's profile
MrRon
4710 posts in 3207 days
#6 posted 07-14-2015 06:27 PM
A 1/4 blade can be tensioned greater than a wider blade. That will result in straighter cuts when re-sawing. I’m guessing you are using a 14” band saw with a 6” riser. That combination doesn’t allow you to get adequate tension when using a wider blade.
View WoodNSawdust's profile
WoodNSawdust
1417 posts in 1140 days
#7 posted 07-14-2015 07:01 PM
- MrRon
What?
Thinking as a mechanical engineer I would think that I could apply more tension to a wider blade before the blade would break than I could apply to a narrower blade.
bigblockyeti
#8 posted 07-14-2015 08:50 PM
I think he’s referring to the fact that any given saw will be able to generate more tension in a blade with a smaller cross sectional area than one with a larger area. That being said, there’s a reason resaw blades are thicker and much wider than something you would use for tight radius work, a 1/4” blade doesn’t have very much beam strength, especially a thin one.
MrRon
#9 posted 07-15-2015 06:31 PM
- MrRon
What?
- WoodNSawdust
I didn’t word this well. What I meant to say was; small/lighter band saws can fully tension a smaller blade than a wider and thicker blade. I have heard of people using narrow blades to re-saw with better results over a wider blade. I’m not not saying wide blades are not good for re-sawing. They are preferred, but you have to have a strong and rigid saw to adequately tension the blade. They sell heavier springs for the tension system, but there is only so far you can go with a light machine.
ForestGrl
#10 posted 07-17-2015 05:14 AM
A 1/4 blade can be tensioned greater than a wider blade. That will result in straighter cuts when re-sawing. I m guessing you are using a 14” band saw with a 6” riser. That combination doesn t allow you to get adequate tension when using a wider blade.
- MrRon
Thanks for this info and the clarifications that followed! My absence the last few days is directly correlated with the amount of time spent using the band saw! First time I’ve used a 3/4” blade, and the Grizzly 1019Z has been brave, but sometimes it does seem like a bit of a slog through the bigger pieces (tallest one was 9”-10” high I think, green maple). I’m going to put a 1/2” blade on it tomorrow to cut some bowl blanks and smaller cherry. One thing that really helped was spraying PAM cooking spray on the blade.
PS: I’ve always used Timber Wolf blades to get the most out of this budget-level saw, they have worked great. Only thing is, I don’t know if the blades hanging on my wall are the ones that work best in green wood. But they will work!
