Help needed : Attaching a vise to mdf mobile assembly table
Forum topic by Ezra posted 10-09-2009 08:55 PM 2032 views 0 times favorited 3 replies Add to Favorites Watch
View Ezra's profile
Ezra
52 posts in 3774 days
10-09-2009 08:55 PM
Topic tags/keywords: assembly table
I am in the process of designing a mobile assembly table that will be doubling as my saw outfield table. Since I am planning on using the top for an assembly table, I wanted a relatively flat surface. For that reason I was going to glue two 4 by 4 sheets of 3/4 mdf and top it off with a 4 by 4 sheet of 1/4 hardboard. My question is regarding attaching my 7 inch front mount vise. I would like to mount this vise on a corner of the bench, but had concerns regarding the strength of the mdf to hold the vise. Specifically will the screws for the vise hold in the mdf, and do I have to worry about sagging? My other option would be plywood, but it is a bit more expensive, and probably not as flat. Any advice.
-- Ezra in Brew City
3 replies so far
View davidpettinger's profile
davidpettinger
661 posts in 3286 days
#1 posted 10-10-2009 03:10 AM
The answer is probably not(will the screws doe the vise hold in MDF). Since I don’t know the dimensions of the front mount style of the vise, my only suggestion would be to remove an area of the MDF top piece and dutch in some 3/4” hardwood only to cover the span of the area for the screws. You could always use a block of 2×4 S4S oak in that corner and glue and screw to the table sub frame.
-- Methods are many,Principles are few.Methods change often,Principles never do.
View ajosephg's profile
ajosephg
1880 posts in 3647 days
#2 posted 10-10-2009 04:57 AM
I think that thru bolts would be better than screws. I have an assembly/outfeed table with a solid core door as the top, which is essentially particle board on the inside. I counter bored holes in the top so that the heads of the bolts would sit slightly below the surface of the table top. I used flat washers under the bolt heads so they wouldn’t dig into the “wood.” Without going downstairs to double check, I used the largest bolt that the vise would accept which was either 3/8 or 5/16.
After about 6 months the table is still flat.
-- Joe
View Ezra's profile
Ezra
#3 posted 10-11-2009 11:41 PM
Thank you both for your response. I spent the entire day Saturday working on this thing, and hope to post some pictures shortly. I haven’t attached the vise yet, as I ran out of time working on it yesterday. I plan to take your advice Joe as I have a 1/4 inch skin of hard board going over the laminated plywood top that will cover up the countersunk bolts. Thanks for the suggestion.
