Are there aftermarket lids for oil-based finishes?
Forum topic by RobinDobbie posted 07-12-2015 11:10 AM 1016 views 0 times favorited 10 replies Add to Favorites Watch
View RobinDobbie's profile
RobinDobbie
147 posts in 1971 days
07-12-2015 11:10 AM
My can of polyurethane varnish has been “abused.” Some by me, some by the store. The stock lid just doesn’t seal, and I still have a few weeks I need this can to hold together. For now, I’ve got it covered with foil. But there has to be a better way. I know they make lids for regular paint, but all I’ve seen is for water-based only.
10 replies so far
View upinflames's profile
upinflames
217 posts in 2398 days
#1 posted 07-12-2015 11:37 AM
Need a few of these in every shop…...
http://www.homedepot.com/p/BEHR-1-qt-Metal-Paint-Bucket-and-Lid-96604/100112530?keyword=empty+paint+cans
You can get them from Uline also, you may not need the 56 in a case though…..
View Redoak49's profile
Redoak49
3739 posts in 2225 days
#2 posted 07-12-2015 01:28 PM
This is an issue for many of us. I use a finishing nail and make some holes in the bottom of the groove and keep them open so it can drip back into can. I also work to keep the groove clean. This works most of the time.
I also will poor some into a smaller disposable container.
I do not think foil is a good idea as it is not air tight.
View Luthierman's profile
Luthierman
222 posts in 1323 days
#3 posted 07-12-2015 01:45 PM
I can get my lids from sherwin williams. Any paint store will have them. Most hardware stores do too. Water based paints and oil based paints are often sent in the same metal can. Any lid should do.
-- Jesse, West Lafayette, Indiana
View Rayne's profile
Rayne
1122 posts in 1776 days
#4 posted 07-12-2015 01:58 PM
I’ve always wanted to try these, but haven’t had a reason to until yesterday. One of my cans of urethane is completely solid because the lid, apparently wasn’t on tight enough, so I may try this; I’d never had to open a lid and it has a built-in stirrer.
http://www.rockler.com/mixing-mate-paint-lid-quart-size-stir-pour-and-store
RobinDobbie
#5 posted 07-12-2015 05:28 PM
- upinflames
Wow, definitely don’t need 56 right off the bat! Might need more than 1 though, since I have a half gallon. Although I see Lowes has the gallon cans for $5. Problem is that part of what happened to my poly can could happen to a new can. I forgot to wipe the inside rim before I closed the lid, then it “glued” shut. Just makes sense to have a lid that closes on the outside of the can so the inside can just stay coated with poly. But it’s goot to know I can buy metal cans.
- Redoak49
The nail trick would have helped, not sure it would have prevented me from forgetting to wipe the inside of the rim, too. The problem is that I go out at night every fer hours and do additional coats. Oh who am I kidding, I’d forget during the day, too.
- Luthierman
I’ll call them and see if what they have is for oil-based. I didn’t think to call a pro shop. Thanks!
I ve always wanted to try these, but haven t had a reason to until yesterday. One of my cans of urethane is completely solid because the lid, apparently wasn t on tight enough, so I may try this; I d never had to open a lid and it has a built-in stirrer.
- Rayne
If I were using lacquer or like in their example shellac, I could consider one of these gizmos. For varnish/urethane I’d be afraid it wouldn’t last long enough to justify the cost.
What I want is something like this: (pour spout optional)
View Yonak's profile
Yonak
986 posts in 1757 days
#6 posted 07-12-2015 05:38 PM
I often use glass jars with screw-on lids. Our local recycling center gets 64oz. and 128oz. pickle jars in large batches from time to time.
The trick with this is to wipe the top lip of the jar real well before screwing on the lid. Otherwise, removing lid can be a challenge.
Regarding punching holes in the trough of paint cans, my experience is that this quickens the drying of the finish in the can as it cuts the seal in half.
RobinDobbie
#7 posted 07-12-2015 07:00 PM
Yeah… that’s the same trick with metal cans! lol
- Yonak
I see that tip a lot and I’ve never done it for that reason.
View WhyMe's profile
WhyMe
1080 posts in 1797 days
#8 posted 07-12-2015 09:47 PM
You can try these….
http://stoplossbags.com/
View tomd's profile
tomd
2186 posts in 4006 days
#9 posted 07-12-2015 10:29 PM
I go to Wally Mart and buy a dozen mason canning jars for about 4 bucks. You can get them in quart, pint and even half pint. They have a rubber seal and often you can use them over.
-- Tom D
RobinDobbie
#10 posted 07-13-2015 03:35 AM
You can try these….
- WhyMe
I like the idea. I usually use a gallon of poly fairly quickly, I just put it on everything because I’m just so lazy. Although the fast-drying properties of shellac have me entranced.
Totally side-tracked question, but does shellac have problems with spilled glue like stain? Part of the reason I don’t stain is because I like lighter colors, but also because glue under stain is nightmarish to fix.
So Sherwin Williams claimed to not have any paint lids what-so-ever. Very interesting and I’m not even sure I believe it.
I guess I’ll have to make something. Shouldn’t be impossible, I just need to find something that’s flexible, airtight, and won’t be bothered by varnish fumes.
I’m sure this isn’t a new idea, but here’s how I’m keeping the brush in there right now. Only works since the can is half-empty. Or is it half full?
