Purchased a Craftsman 21833 today
Forum topic by Trey posted 07-12-2015 04:37 AM 826 views 0 times favorited 5 replies Add to Favorites Watch
View Trey's profile
Trey
84 posts in 1946 days
07-12-2015 04:37 AM
Well, after shopping and reading long enough, i bought a 21833 today. I wanted the Delta 36-725. Lowes proved to be annoying with ordering, and in the end, it was going to take a month or two to get it.
The trunnion issue has been fixed. As long as I back off the knob, my readings stay true. I already have an Incra miter gauge for it. I’ve had that for over a year, and am finally glad to use it.
The only issue I have had so far is the set screw on the motor pulley. Fixed it twice, still backed off, so I added some loctite the third time. We’ll see if that helps.
I’m looking forward to making good, repeatable cuts.
5 replies so far
View knotscott's profile
knotscott
8185 posts in 3617 days
#1 posted 07-12-2015 10:22 AM
If the set screw loosens again, check for a second set screw underneath the top one and tighten that too if there is one. Congrats on the new saw.
View diverlloyd's profile (online now)
diverlloyd
3293 posts in 2098 days
#2 posted 07-12-2015 01:17 PM
Loctite it. But red the direction first and choose the right one.
View John L's profile
John L
148 posts in 1405 days
#3 posted 07-12-2015 01:32 PM
I’m glad they fixed that problem. I read somewhere that the problem was most likely caused by the product being dropped/damaged in transit. Can’t remember where I found it earlier.
Dayton Electric, the maker of this saw, along with some other outlets, has a solid reputation of doing excellent work.
I’m surprised thought, that it has a 15 Amp motor. I would have thought it might have had at least a 17 Amp, or higher rating. My old 1981 Craftsman has a 17 Amp motor.
-- Tolerance becomes a crime when applied to evil - Thomas Mann
View Luthierman's profile
Luthierman
222 posts in 1328 days
#4 posted 07-12-2015 01:44 PM
About the loctite, I have always said, Red, you’re dead. That stuff wont come loose without a lot of heat and persuasion. If you want back in sometime use the blue.
-- Jesse, West Lafayette, Indiana
View SuperCubber's profile
SuperCubber
1048 posts in 2526 days
#5 posted 07-12-2015 02:37 PM
Congrats on the new saw!
-- Joe | Spartanburg, SC | "To give anything less than your best is to sacrafice the gift." - Steve Prefontaine
