I dyed an oak table top but forgot to burnish first, now its blotchy, how do I fix it?
Forum topic by Mauricio posted 1318 days ago 1016 views 0 times favorited 3 replies Add to Favorites Watch
View Mauricio's profile
Mauricio
5103 posts in 1318 days
1318 days ago
Topic tags/keywords: question aniline dye oak blotchy blotch finish stain
In my rush to get this project done I forgot to burnish the surface of the oak table top with a gray abrasive pad before applying the dye last night. I checked the table top this morning and it dried blotchy.
I did burnish the base of the table and there are no issues so I’m pretty sure this is the issue.
Can I burnish it now and reapply the dye to even it out? Should I lighten the color somehow before doing this so it doesn’t end up darker than I want?
I would appreciate any help you guys can give me.
3 replies so far
View lcurrent's profile
lcurrent
92 posts in 1982 days
#1 posted 1316 days ago
Mochoa If you will take Denature Alcohol on a thin piece of thin felt ( no Dye ) it will smooth out the dye and dont change the color
Larry
-- lcurrent ( It's not a mistake till you run out of wood )
Mauricio
#2 posted 1316 days ago
Thanks Larry,
I kind of did what you suggested. But, since I mixed the dye with distilled water, I rubbed out the dark spots with a wet rag and then reapplied the stain. I think it looks ok.
Thanks for the input.
86997 posts in 1744 days
#3 posted 1313 days ago
House hold bleach will remove water base dye. clean then spray a 1lb coat of shellac scrub with 320 and re apply dye
