How long in vacuum press?
« back to Joinery forum
Forum topic by mark4345 posted 07-12-2015 12:25 AM 1974 views 0 times favorited 5 replies Add to Favorites Watch
View mark4345's profile
mark4345
71 posts in 2421 days
07-12-2015 12:25 AM
How long do you typically leave the vacuum press going? Usual clamp time 30 mins to an hour?
5 replies so far
View AlaskaGuy's profile
AlaskaGuy
4135 posts in 2307 days
#1 posted 07-12-2015 01:13 AM
I don’t know a lot about vacuum pressing. But I’m betting those that do will want to know,
What glue are you using?
What materials are you gluing?
Stuff like that.
mark4345
#2 posted 07-12-2015 01:28 AM
Good point. Titebond 3, i am gluing a 1/8th inch piece of mahogany to timberstrand.
I’m building a front door and using the timberstrand as the core
AlaskaGuy
#3 posted 07-12-2015 03:35 AM
The web site says yellow glue is not the best for veneering.
http://www.joewoodworker.com/veneering/glues.htm
Found this on another web site.
Glue Type Drying Time
Yellow Glues 1 to 4 Hours Small pieces (braces on the inside of a guitar can dry in as little as 20 to 30 minutes. 4’ x 8’ panels can take as long as 3-4 hours.
White Glues 2 to 6 Hours Gives more open time than yellow glues.
Urea Glues 4 to 6 Hours Urea glues need to be at 70º or higher for proper curing and the piece
should set over night before machining
Polyurethane 1 to 6 Hours Depends on manufacturer and conditions
Epoxies 5 min to 24 Hours Epoxies are two part systems where a catalyst is added to cause it to harden. Most allow you to control the set time by the amount of hardener that is added.
1/8 thick veneer is border line of being to thick from some points of view.
I thinking you need to do some more research before proceeding. Again I’m not a expert but just giving an opinion from some of the stuff I read about veneering.
A good place to start is http://www.joewoodworker.com/
4986 posts in 2492 days
#4 posted 07-12-2015 11:45 AM
I always use an urea-formaldehyde glue, and leave it in overnight. If I ever do use PVA, I’d probably go with something along the lines of what AlaskaGuy suggested. Whatever you do, you don’t want to rush it, you can screw it up taking it out too early, but it won’t hurt to spend a little extra time in the bag…..I really think 1/2 hour is rushing it.
View bonesbr549's profile
bonesbr549
1549 posts in 3065 days
#5 posted 07-12-2015 01:57 PM
I always use an urea-formaldehyde glue, and leave it in overnight. If I ever do use PVA, I d probably go with something along the lines of what AlaskaGuy suggested. Whatever you do, you don t want to rush it, you can screw it up taking it out too early, but it won t hurt to spend a little extra time in the bag…..I really think 1/2 hour is rushing it.
- Fred Hargis
+1. What he said. If you remove early you can get a bubble.
