how to apply a gradient stain
Forum topic by Matt1475 posted 07-11-2015 02:11 PM 1219 views 0 times favorited 9 replies Add to Favorites Watch
View Matt1475's profile
Matt1475
58 posts in 1493 days
07-11-2015 02:11 PM
Topic tags/keywords: stain
I am making a box for my brother in the Marines, and i want to try to replicate this box. http://vintageeditions.com/wp-content/uploads/2014/03/ITEM-65030.jpg
I dont know how to apply a gradient stain and i cant find much about it. Any help is appreciated
9 replies so far
View Daruc's profile
Daruc
460 posts in 1129 days
#1 posted 07-11-2015 02:17 PM
Use a touch up spray gun. Harbor Freight for cheap.
http://www.harborfreight.com/touch-up-air-spray-gun-66871.html
View Dez's profile
Dez
1166 posts in 4074 days
#2 posted 07-11-2015 04:22 PM
wooddust has it. Spraying is the easiest way.
I’ve done it by hand, adding additional coats of stain where it needed to be darker and it came out ok but spraying is far easier.
-- Folly ever comes cloaked in opportunity!
View bondogaposis's profile
bondogaposis
4727 posts in 2348 days
#3 posted 07-11-2015 05:20 PM
Stain the box evenly, when dry, spray the corners with a second coat of stain.
-- Bondo Gaposis
View jwmalone's profile
jwmalone
769 posts in 699 days
#4 posted 08-25-2016 02:10 PM
Those guys are right, but id practice on a couple cardboard boxes or something. You have to get the angle right, but its not difficult.
-- "Boy you could get more work done it you quit flapping your pie hole" Grandpa
View DrDirt's profile
DrDirt
4424 posts in 3739 days
#5 posted 08-25-2016 02:58 PM
Use a spray toner – - stain the box, and apply first coat of clear.
Then get a rattle can of dark walnut toner (basically Lacquer with dye). and hit the corners/edges.
This is also the technique to tweak finish repairs to blend in a repair to match surrounding color.
$ 8.99 at woodcraft. the Behlen brand is the Consumer/hobby division of Mohawk.
View dbray45's profile
dbray45
3320 posts in 2773 days
#6 posted 08-31-2016 12:26 PM
If you plan to do a bunch of this, look at using an air brush. Sometimes spray cans are not very consistent and splotchy.
-- David in Damascus, MD
Matt1475
#7 posted 08-31-2016 12:40 PM
I ended up doing it with a rag. It took alot of feathering in and a little practice on scrap boards, but it turned out pretty good. Key was to start with very little in the rag and really press hard to force the stain in the wood exactly where you want and how much you want.
dbray45
#8 posted 08-31-2016 12:50 PM
Good job – will keep that in mind
View TheGreatJon's profile
TheGreatJon
337 posts in 1230 days
#9 posted 08-31-2016 01:22 PM
^ Nice!
-- This is not the signature line you are looking for.
