Advice on 30 degree cuts
Forum topic by OneEye posted 07-11-2015 03:12 AM 762 views 0 times favorited 7 replies Add to Favorites Watch
View OneEye's profile
1 post in 988 days
07-11-2015 03:12 AM
Topic tags/keywords: question
Absolute newbie here and to the woodworking game. Will have plenty of questions and reading up to do that’s for sure.
I was just wondering if anyone had some advice on how to go about accurately cutting some 30 degree cuts so that they come together in this fashion….
I have a table saw and have made a few jigs in the past but am unsure how to tackle this one. As always its probably a simple answer!
7 replies so far
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3649 days
#1 posted 07-11-2015 03:51 AM
Would a table saw sled with a 30 degree wedge and some stop blocks give you the solution you are looking for?
View Gopher's profile
27 posts in 1883 days
#2 posted 07-11-2015 05:08 AM
Miter Saw would be best. Set a stop block for length, cut, flip cut.
Table Saw sled at 30 would also work
-- Ted T. Aiken S.C.
View BadJoints's profile
103 posts in 1025 days
#3 posted 07-11-2015 10:14 AM
What they said. Another suggestion would be a fixed/adjustable shooting board so you can fine tune the angles with a hand plane for a perfect fit. Both my TS and Mitre Saw have too much slop, so I almost always use the shooting board afterward. Air tight fit.
-- Producing furniture grade firewood since 1984
View rwe2156's profile
2846 posts in 1417 days
#4 posted 07-11-2015 10:56 AM
Table saw sled or miter saw + several trial cuts = perfect angles.
Use a shooting board if necessary to clean up the cut.
Obviously use scraps to dial in your set up.
View MrRon's profile
4676 posts in 3180 days
#5 posted 07-11-2015 06:52 PM
Trial and error is the time honored method of getting any joint to fit. You think those furniture factories just push wood through a machine and out comes a finished piece? A lot of trial and error was used to set that machine up to make the perfect cut. Once set up, they can run wood through all day long and everything will come out the same. A home shop is different. We are not doing production work, but the same situation exists in making joints. You just can’t escape trial and error. No machine that I know of, available to the home woodworker can make perfect cuts right out of the box. How do you think furniture makers hundreds of years ago did it; trial and error. Too many woodworkers think a fancy, pricy tool will solve their problems. It always boils down to T&E. The angles used on your example require a precise angle, an angle that no machine will register. If you are off just a few seconds of a degree, the mismatch will show.
View Yonak's profile
986 posts in 1458 days
#6 posted 07-11-2015 07:53 PM
The 30° mitres should be fairly easy on a table saw or mitre saw. The trick is to get the point exactly in the middle. You may try making the rails extra wide and long and, after cutting the mitres, trim the edges and cut to length so the point is in the right place and the rails are the correct width and length.
View daddywoofdawg's profile
1028 posts in 1512 days
#7 posted 07-11-2015 07:56 PM
miter saw would be my go to.It has miter in the name.
