"chatter" when using router table
Forum topic by bobbycakes posted 07-11-2015 03:12 AM 957 views 0 times favorited 9 replies Add to Favorites Watch
View bobbycakes's profile
bobbycakes
5 posts in 1044 days
07-11-2015 03:12 AM
I’m trying to trim a 3/16” piece of maple that I am using as a plywood edge-band. I’m using a brand-new bit but instead of a smooth surface I’m getting a few spots of chatter. Is that because the rotation of the bit is too fast or maybe too slow (I have it set a about 22000 rpm)? I’m only taking a very small sliver off the piece.
9 replies so far
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3706 days
#1 posted 07-11-2015 03:39 AM
IS this banding already fastened to the plywood?
View exelectrician's profile
exelectrician
2327 posts in 2420 days
#2 posted 07-11-2015 03:40 AM
Check for loose fit between your router plate or lift and the hole it sits in.
-- Love thy neighbour as thyself
bobbycakes
#3 posted 07-11-2015 02:57 PM
Yes Mark. The banding is already attached to the plywood.
View MrRon's profile
MrRon
4757 posts in 3237 days
#4 posted 07-11-2015 07:06 PM
Are you using a straight bit or a spiral bit? The latter would give you a better cut. Also who makes the bit you are using? Not all bits are created the same.
bobbycakes
#5 posted 07-11-2015 07:37 PM
McRon – I ‘m using a almost new straight bit from Freud. But it is not a spiral bit – that may be the problem. Should I do anything with the speed?
View Ghidrah's profile
Ghidrah
667 posts in 1215 days
#6 posted 07-11-2015 09:35 PM
Are you using a fence? What direction are you feeding the mat, L-R or R-L? Are there any missing bits of carbide on the bit?
The only spiral bits I have are for inlay, the rest are straight, to date I can’t ever recall getting chatter on material unless it was against a crazy grain pattern and or I was improperly attempting a climb cut.
-- I meant to do that!
bobbycakes
#7 posted 07-12-2015 12:12 PM
Ghidrah,
I am using a fence and I am feeding the material from right to left across the bit. I haven’t noticed any nicks or bits of carbide missing from the bit.
View Nubsnstubs's profile
Nubsnstubs
1286 posts in 1723 days
#8 posted 07-12-2015 01:52 PM
hey BC, a couple swipes with sandpaper and you’d never know there was chatter. Stop fretting, unless you have big time tearout, which you might need to either putty or remove the banding, and replace with another piece. You are a woodworker, and if you’ve done it awhile, you’ll notice wood doesn’t always cooperate with your wishes.
If it’s a new bit with a 1/4” shank, it’s possible it might have a bent shank. Holding the router with bit end up, turn it on and look at the center of the bit. If you see a smooth center , you’re good on the bit and router, If it doesn’t look smooth, the bit is bent or your router needs bearings. That’s the best I can do on explaining how to check bits. ......... Jerry (in Tucson)
runswithscissors
2750 posts in 2018 days
#9 posted 07-16-2015 07:47 AM
Is it possible you have a bit of runout? Either in the shaft, or in the shank of the bit?
