| Forum topic by bentlyj | posted 45 days ago | 256 views | 0 times favorited | 10 replies | ![]() |
45 days ago |
45 days ago |
It is a six tooth fligger cutter. Most are only 5 toothed, but yours seems to be a special design. I use ‘em mostly when cutting multiple fliggers in WilsonArt laminates. Fliggers are soooo neat. |
45 days ago |
Looks like a miter fold bit. CW |
45 days ago |
The latest in hemorrhoid removal tools. |
45 days ago |
Slot Cutter bit for joining 2- 45 degreee cuts to properly join a 90 degree corner???? -- Easy Peasy Lemon Squeezy-May all your dovetails fit tight and right the first time |
45 days ago |
Sizz wheel for a smoke grinder? -- I'm a lumberjock and I'm ok, I sleep all night and I work all day! |
45 days ago |
it creates the groove that the laminate edges on the table go in…. cant really explain it but it makes sense im my head :? |
45 days ago |
I would say that the 45 degree angle is set with a guide to put a back bevel on the edge of the laminate for a 90 degree face and the 22 1/2 degree is flipped over and adjusted for 45 degree edges. The blade is inset into the base of the tool so as to have one bevel functioning at a time. -- Oldworld, Fair Oaks, Ca |
45 days ago |
I thought it was a slot cutter for “T” moldings. ? That’s my best guess, or it could be a fligger cutter, or a Sizz wheel or the latest in hemorrhoid removal. LOL -- John @ Myrtle Beach |
45 days ago |
It would sure remove hemmoroids for sure….......Ouch….........LOL -- Jerry--A man can never have enough tools or clamps |
45 days ago |
Charles has it right. (must of used one before) :) This is used to make mitre folds on laminate doors. By 45ing all the edges it eliminates the black lines normally associated with laminate. (even the corners come out mitered)
| Forum | Topics |
Woodworking Skill Share
2897 |
3909 |
255 |
941 |
220 |
Woodworking Trade & Swap
617 |
Coffee Lounge
2363 |
LumberJocks.com Site Feedback
522 |
