Very old jointer on CL - what problems to look for?
Forum topic by JeffP posted 07-10-2015 10:11 PM 817 views 0 times favorited 4 replies Add to Favorites Watch
View JeffP's profile
JeffP
573 posts in 1419 days
07-10-2015 10:11 PM
Topic tags/keywords: question jointer
I’ve been negotiating with the owner of a circa 1905 12” jointer (American WW machinery co).
I haven’t gone out to look at the machine yet. It is in need of a new motor, so I won’t be able to see it actually joint some wood.
Claims the bearings (“babbits”) have been “re-poured” (near as I can tell from my googling, this basically means the bearings have been re-manufactured to more or less new).
Supposedly has a 3 knife cutter head. Don’t know what condition the knives are in. Anybody know if I would be able to retrofit some new knives into this ancient beast without replacing the whole cutter head? Also, would it require major machining to take a modern helical head and make it work in such a machine?
If/when I go out to look at this thing, what all should I do to thoroughly kick the tires? (as I said, won’t be able to run it)
thanks much!
-- Last week I finally got my $*i# together. Unfortunately, it was in my shop, so I will probably never find it again.
View Kyheadhunter's profile
Kyheadhunter
40 posts in 1667 days
#1 posted 07-11-2015 07:30 PM
Look for a level table. Is the jointer a direct drive or belt driven. You should be able to convert to belt driven if needed. Is there rust on the table, how bad is it. Its a heavy beast, you have to be very careful moving it, not to tip it over. You could disassemble, but I moved mine in one piece. Does the cutter head turn smooth? New knives shouldn’t be a problem.
4999 posts in 2520 days
#2 posted 07-11-2015 07:38 PM
Knives shouldn’t be a problem, and you could have a helical head made if you want and money allows. As kyheadhunter said, the weight of the thing may be a challenge…but really, these old machines are built for the long haul, so if the visual inspection is good, it’s likely a worthwhile candidate.
JeffP
#3 posted 07-11-2015 11:30 PM
thanks all. I spent an hour moving and removing stuff in my shop this morning…and eventually gave in to the reality that I simply don’t have room for this wondrous beast right now.
Mostly, I came to realize that I need to ignore these CL ads for huge vintage iron until after I build my new shop building (circa 2017).
View HerbC's profile
HerbC
1764 posts in 2886 days
#4 posted 07-12-2015 04:33 PM
If you don’t buy it when you find it, you’ll never find it when you think you have enough room…
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
