Wood frames for ceramic art?
Forum topic by Tim from Iowa City posted 51 days ago 322 views 0 times favorited 10 replies Add to Favorites Watch
View Tim from Iowa City's profile
Tim from Iowa City
186 posts in 499 days
51 days ago
My wife recently bought some expensive ceramic or porcelain tiles. She would like me to put a two inch frame around each tile. I am using quartersawn white oak—craftsman look. Anyway, I am trying to figure out how to attach the tile to the frame. The tile is fairly thick – 5/8 inch thick tile. There will need to be some movement allowed for expansion/contraction of the wood frame. It also needs to be flush in the back as the framed tiles will be mounted/hung on the wall. Any ideas?
-- Tim from Iowa City, IA
View mics_54's profile
mics_54
432 posts in 370 days
51 days ago
I use construction adhesive and sanded caulk available in many shades at THD or no caulk if its a single tile. This would preclude there being a back to which to attach it.
-- Dan, Sterling Alaska, http://sullcon.homestead.com/ Before you criticise some one, walk a mile in their shoes...then you will be a mile away and you have their shoes!
View CaptainSkully's profile
CaptainSkully
496 posts in 458 days
50 days ago
On my Dard Hunter frame, I fit the frame snugly around the tile and used a dado groove underneath to house a 1/4” backer board to glue them to. This squared the assembly, and allowed me to push the tile forward. I used 3M 4200 to glue the tile to the backer board as I work in the boating industry.
Dard Hunter Frame
For the frames I need to make for the SF Arts & Crafts Show tile we won, and the Yoshiko Yamamoto’s Montana del Oro tile I still need to make, I’m going to use much thicker stock for the frame and the tile will be partly covered over by the dado. This gives a much more finished look to the tiles that tend to have rounded/random edges/corners.
-- You can't control the wind, but you can trim your sails
mics_54
50 days ago
nice!
CaptainSkully
50 days ago
I’ve been intrigued by the sanded grout mix to fill the gap between the wood and the tile, but I’ve always been afraid the abrasive would jeopardize the tile or the wood finish. My father-in-law grouted in the Motawi tile he gave my better half for her 40th. I never actually got around to asking how to you prioritize grouting and finishing wood around an expensive tile.
Tim from Iowa City
48 days ago
Thanks Captain. That picture shows exactly what I am trying to do.
Mics—thanks for the help as well. I’ll try the backer board and adhesive. Tim
View drgoodwood's profile
drgoodwood
389 posts in 1027 days
48 days ago
I collect vintage art and decorative tiles from my area; Kentucky, Ohio and Indiana.
While I will glue a non-valuable tile to a backer board, I won’t do that if the tile has any collectible value.
I usually inlet the frame, then use brass frame clips on the rear side to hold the tile in place.
Often, it is important not to deface the back of the tile and to see the makers marks.
Here’s an example of the type of clips I use:
Lee Valley
-- Randy, Rustic Artisan, a family tradition. (No PM's - auto-deleted.) - "I am a seeker, not a follower."
CaptainSkully
46 days ago
Ah… In my naivete, I glued a set of Motawi tiles to the backer board. For all our other tiles, I will use those clips. One of our tiles is actually 1/1 series. Pretty cool. Thanks for the advice.
mics_54
46 days ago
You can buy sanded siliconized caulk grout that is much easier to use and it stays flexible. and expands /contracts. Available in typical grout colors. I am using it on some table tops now.
View Napaman's profile
Napaman
3492 posts in 976 days
46 days ago
check out dan’s work…he makes some amazing frames for his work…not porcelin squares but his work may give you some ideas…
View Dustmite97's profile
Dustmite97
182 posts in 119 days
41 days ago
Yeah, check out Dan’s work.
-- Remember, measure twice, cut once
