Can you tell me If I am wasting my time
Forum topic by lcurrent posted 07-10-2015 05:36 PM 1463 views 0 times favorited 14 replies Add to Favorites Watch
View lcurrent's profile
lcurrent
125 posts in 3813 days
07-10-2015 05:36 PM
Can anyone tell me where I am going wrong I have a jig that will cut a mortise or dowel without moving anything once you are set up for that size it will take stock from 1/16 to 6 1/4 inches cut mortises from
smallest size you can find to 1/2 inch with a length 4 1/2 inches You can put 3 mortises side by side in a 4×4 the jig will hold a sheet 3/4 plywood ( gripped in the center )
It weighs 17.5 lbs takes 10” x 24” is portable can mount on a 2×6 ( Like mine is ) and just clamp to the the work bench when not in use
If you are gluing up a top you can step the dowels or mortise they will all register when stepping Dowels there will be 4 per 16 inches Mortises there will be 2 per 16 inches and since you register off the solid
clamp bar on that side you will stay flat on that side and the Mortise or Dowel will keep that call that the top My problem is no one seems to have the problems with the Mortising Machine that I had when I was using one . Not counting cutting the tenons on the table saw with a tenoning jig
Now I use Dowels Or Loose Tenons
No photos If you want them lcurrent2000@gmail.com
-- lcurrent ( It's not a mistake till you run out of wood )
14 replies so far
View lepelerin's profile
lepelerin
495 posts in 2323 days
#1 posted 07-10-2015 06:29 PM
a picture would help to understand your issue. Why not post a pic on the forum instead of having to request for it.
You would certainly get more help by posting it here.
lcurrent
#2 posted 07-10-2015 08:12 PM
lcurrent
#3 posted 07-10-2015 08:12 PM
lcurrent
#4 posted 07-10-2015 08:16 PM
View alittleoff's profile
alittleoff
539 posts in 1274 days
#5 posted 07-10-2015 08:33 PM
This one is over my old head.
Sorry or
Sorry Gerald sometimes I really don’t know. :-)
View rwe2156's profile
rwe2156
2925 posts in 1478 days
#6 posted 07-10-2015 09:50 PM
Until you find a better way of explaining what you’re doing I don’t think anyone can help you.
View JoeinGa's profile
JoeinGa
7736 posts in 2005 days
#7 posted 07-10-2015 10:02 PM
Look at these other posts he made. I think you’ll understand what he wants then …
http://lumberjocks.com/topics/64324
http://lumberjocks.com/topics/64507
http://lumberjocks.com/topics/65955
http://lumberjocks.com/topics/98122
View MrRon's profile
MrRon
4769 posts in 3241 days
#8 posted 07-11-2015 07:53 PM
If the jig works for you, why do you think it is a waste of time?
rwe2156
#9 posted 07-11-2015 09:02 PM
OK, so now that I’ve seen the video its a lot clearer.
I waded through the post again but I don’t see a statement of what the “problem” is so maybe somebody can help you.
JoeinGa
#10 posted 07-12-2015 10:57 PM
I think he’s trying to market this thing ?
View gfadvm's profile
gfadvm
14940 posts in 2688 days
#11 posted 07-13-2015 12:08 AM
I had the same thought Joe. If so, he’s wasting OUR time.
View ChuckV's profile
ChuckV
3118 posts in 3525 days
#12 posted 07-13-2015 12:55 AM
You need to:
(1) Invert the eigenvalues.
(2) Re-calibrate the dilithium crystals.
This fix should only take a few hours, unless the dilithium crystals are the old top-quark type.
-- “Big man, pig man, ha ha, charade you are.” ― R. Waters
View waho6o9's profile
waho6o9
8190 posts in 2575 days
#13 posted 07-13-2015 04:12 AM
The old top-quark type? Very astute!
View AlaskaGuy's profile (online now)
AlaskaGuy
4135 posts in 2307 days
#14 posted 07-13-2015 10:37 AM
lcurrent,
Like the others I’m a bit confused on what you are asking. You ask “what am I doing wrong” but don’t tell us what problem you’re having with the jig.
Usually when someone ask that question “what am I doing wrong” about a jig or tool they either don’t know how to use the jig or the jig just doesn’t work very well.
You need to be more clear with what’s wrong with your jig if anyone is going to be able to help.
