Help with Drum Switch on Grizzly Shaper
Forum topic by Shanem posted 07-10-2015 01:42 PM 2373 views 0 times favorited 12 replies Add to Favorites Watch
View Shanem's profile
Shanem
130 posts in 2434 days
07-10-2015 01:42 PM
So I bought a used 1 1/2 hp grizzly shaper. The previous owner upgraded to a 2hp leeson motor (110402). He attempted to wire the switch but it only works in reverse. I’m trying to wire it up for FW/Rev but the grizzly manual only has color codes and no T numbers. Also, there is no make or model on the drum switch. must be a Taiwanese one. It has 6 connection spots on each side.
Any help with wiring this for 220V?
12 replies so far
View REO's profile
REO
928 posts in 2042 days
#1 posted 07-10-2015 10:01 PM
is it a capacitor motor?how many leads available in the packing head of the motor?what are the letter and number designations on the switch?
View JeffMartineau's profile
JeffMartineau
78 posts in 1021 days
#2 posted 07-10-2015 11:01 PM
Do you have a clearer picture of the switch? In general, you can follow this pattern for what you want to achieve:
Edit: Don’t forget the ground and neutral, usually green and white. The drawing doesn’t show their positions, but it should be marked on the switch. I see the NS flag, are you in the Halifax area?
-- -Jeff. My shop is huge, it just doesn't have a ceiling. Or walls.
View 01ntrain's profile
01ntrain
254 posts in 1038 days
#3 posted 07-10-2015 11:28 PM
That connection is temporary, right?
View MrUnix's profile
MrUnix
6598 posts in 2167 days
#4 posted 07-11-2015 12:03 AM
That diagram will work for a DC motor (note the +/- indicators), but not for a typical AC induction motor. What does the wiring diagram on the motor look like? I may not be possible to reverse directions on it.
JeffMartineau
#5 posted 07-11-2015 12:38 AM
Searched the interweb and found the wiring diagram for the motor. Good news is it is reversible yaaay! I’ll try to make the drawing user friendly for you!
JeffMartineau
#6 posted 07-11-2015 02:54 AM
WARNING:
THIS SETUP WILL PERMIT YOU TO CONTROL THE MOTOR, BUT IT WILL ALWAYS HAVE A VOLTAGE GOING TO IT. UNPLUG THE MACHINE AFTER EVERY USE !!!
THE 2 HP LEESON IS A CAP START, CAP RUN. THIS SWITCH IS MADE FOR CAP START, INDUCTION RUN. YOU NEED A NEW SWITCH.
And sorry for the NS flag, wouldn’t want to insult a true Newfoundlander!
Shanem
#7 posted 07-12-2015 11:30 PM
Hey jeff,
I just hooked this up as you have indicated, doesn’t spin. Just hums in both directions.
I removed all jumpers as you identified by the red arrows. Is this correct?
JeffMartineau
#8 posted 07-13-2015 09:16 AM
Hard to say. You should not need those jumpers on a regular switch, but without being there to test it’s operation, I can’t really say yay or nay. It did work in the one direction before, so maybe it does operate on a different pattern than what I thought. Is this the original switch?
Shanem
#9 posted 07-13-2015 10:17 AM
it is the original switch. Here is the switch wiring diagram from the manual. It only has wire colors and no T#’s.
Shanem
#10 posted 07-13-2015 10:22 AM
In addition to the jumpers they have indicated, there are metal connecting strips between U-5, R-blank top, S-blank bottom.
I looked to see if these colors are universal and could not find anything definitive.
View REO's profile
REO
#11 posted 07-13-2015 08:58 PM
You will find the “T” numbers on the leads of the motor inside the packing head of the motor. your goal with the replacement harbor freight motor is to switch the T5 and T8 leads. The original diagram may not be any good for the new motor.
One line goes to T1
one line goes to t4 which is connected through the switch t5 in CCW and t8 in CW
t2 and t3 are tied together and connected through the switch to T8 in CW and to T5 in CCW
copy and paste this into your browser for a pictorial.
https://www.google.com/search?q=wiring+a+single+phase+reversing+drum+switch&espv=2&biw=1920&bih=985&tbm=isch&tbo=u&source=univ&sa=X&ved=0CCAQsARqFQoTCPGF__f92MYCFUcTkgodnkUATA&dpr=1#imgrc=EmpEX3ISfIZZoM%3A
Shanem
#12 posted 07-14-2015 12:53 PM
Thanks all for your replies. I got fed up with the switch not working so I decided to disassemble it and see exactly how it made connections in FW/Rev. While doing so I discovered that a contact had melted and wasn’t making a connection in forward. So after all this I need a new switch….
Encase anyone down the road has an issue with this particular switch and wondering how it makes connections, here goes.
In Forward:
R,5, Blank
All closed
6,S, blank
In Reverse;
U,R,blank
All closed
S,V,blank
These switches are cheaply made with a plastic cog that initiates small contacts. I believe I am going to just buy a double pole switch and manual change 5&8 if I ever need to reverse. And down the road if I find I do it often, I will buy a better quality drum switch.
