Small Combo Square Needs Knurled Nut and Spring
« back to Hand Tools forum
Forum topic by Mattyboy posted 07-10-2015 04:58 AM 964 views 0 times favorited 11 replies Add to Favorites Watch
View Mattyboy's profile
Mattyboy
50 posts in 983 days
07-10-2015 04:58 AM
Topic tags/keywords: question combination square
Some months ago I found this 6” Brown & Sharpe combo square at a garage sale, but it did not have the knurled nut and spring to use with the clamp screw that holds the blade to the stock. I tried finding the right size nut at McMaster and at specialty fastener stores with no luck. The threads have an outer (major) diameter of 0.208” and I’m pretty sure there are 28 threads per inch. Apparently not a standard size. Finally I called Brown & Sharpe and they said they would send me a new clamp screw assembly (which includes clamp screw, nut and spring). They never did, so I bought one myself.
You can see the problem in the picture – the clamp screw I bought is a lot bigger than the original and will not fit in the stock. I guess this square was made before B&S standardized all their squares with one size clamp screw assembly.
Can anybody suggest a way to get this square working again? I’m not a machinist, so making my own is not a solution for me.
Thanks for helping.
-- Matt, Northern CA
11 replies so far
Mattyboy
#1 posted 07-12-2015 07:25 PM
Anyone? ...... Anyone? (nudge)
View upchuck's profile
upchuck
540 posts in 1570 days
#2 posted 07-12-2015 09:34 PM
Mattyboy-
Just so you won’t feel like you’re wandering around lost in the woods.
Good luck. Keep you eyes open for broken combo squares. Save all of the parts. Continue to use the ruler while you wait.
chuck
View Ripthorn's profile
Ripthorn
1454 posts in 2890 days
#3 posted 07-12-2015 09:47 PM
The OD you describe is very close to #12 (like, a few thousandths off). #12-24 is a standard size, you could see if that is what it is by going to the hardware store or something. If it really is a non-standard size, you have a couple options. One is to try to source a new nut from another unit, another is to go to a machinist and have them make you a new one, the last is make friends with someone who can make one. However, note that having one made you will not get the same knurling pattern as the original. The originals had this great decorative knurling that simply is not made any more (and finding vintage knurls to make them is incredibly expensive).
View bandit571's profile
bandit571
19195 posts in 2588 days
#4 posted 07-12-2015 09:48 PM
Go out to Menards/Lowes/whatever. Pick up a small combo square that looks like the right size hardware on board. Take the head of your square along, and test it out.
View TheFridge's profile
TheFridge
8881 posts in 1391 days
#5 posted 07-12-2015 10:05 PM
Sounds like a #12-28 (fine thread).
View JoeinGa's profile
JoeinGa
7733 posts in 1912 days
#6 posted 07-12-2015 11:07 PM
I’d carry that clamp-screw in my pocket EVERYWHERE I went. You never know when a hardware store, big box or even a flea market might just have something to fit. And it doesn’t necessarily have to be an oversized knurled knob type. Even if you found a hex nut the right size you could JB Weld a larger hex nut to it for the grip.
View Ghidrah's profile
Ghidrah
667 posts in 1127 days
#7 posted 07-13-2015 12:32 AM
If you could find a standard/metric bolt that fits the hole diameter, with some time, a hacksaw and a couple files you could reproduce the original close enough to work.
-- I meant to do that!
View Tim's profile
Tim
3733 posts in 1866 days
#8 posted 07-13-2015 01:16 AM
Fridge is probably right. #12-28 is a UNF standard size and #12 is .2160 major diameter. It doesn’t seem too surprising to be 62 thousandths smaller than the standard, but I’m no expert. It would be easier to buy and test a #12-28 than it would be to find a caliper designed to measure the minor diameter so try finding the screw first like Brian said.
Mattyboy
#9 posted 07-13-2015 03:34 AM
Some great suggestions, all. Thanks a lot for that. I don’t need this to be perfect – just good enough to work.
Thanks again.
Mattyboy
#10 posted 07-13-2015 11:01 PM
Well, thanks to some advise from the people above, I now have a working square. I was able to find a plastic knurled knob, a metric M-6×1.0 nut and a spring to get this thing functional again.
The M-6 doesn’t fit the clamp screw quite right, but it’s close enough for me to lock the blade to the stock of the combo square.
The knurled knob was made to fit a cap head machine screw, so it had a “housing” that would fit the spring, much like the brass knurled nuts for combo squares do. I drilled out the knurled knob (already drilled out in photo above) and filed until the M-6 nut fit, then epoxied it in place.
Cut a short length of the spring to provide back pressure to keep it together when adjusting the square.
Just a few bucks spent and a great result. And because the knurled knob is black like the stock, it doesn’t look too bad. Thanks to all for your suggestions.
View Tim's profile
Tim
#11 posted 07-14-2015 12:08 AM
I have to say I’m a little shocked the metric threads worked, but I’m glad you got it fixed up so you have a working square again. Nicely done.
