Safety of a different sort - safe to use pressure treated lumber inside?
Forum topic by ChrisBarrett posted 07-09-2015 08:19 PM 1204 views 0 times favorited 17 replies Add to Favorites Watch
View ChrisBarrett's profile
ChrisBarrett
99 posts in 1054 days
07-09-2015 08:19 PM
So without realizing it, I chopped up a pressure treated 2×8 last night inside the basement to use for my planer stand. This appears to be the MCQ variety of pressure treated lumber. So I have two concerns, one is the sawdust not captured by the dust collector being tracked around the house and then the fact of using this stuff for inside use such as a workstand. Is it safe to keep inside? I know if there’s a fire this stuff can put out toxic fumes.
Anyone on the forum a materials expert? :-D Thanks for your advice.
edit This stuff is Micronized Copper Quaternary. Also wife is preggo and I don’t want to be tracking potentially hazardous stuff around! :-/
17 replies so far
View skatefriday's profile
skatefriday
416 posts in 1479 days
#1 posted 07-10-2015 01:40 AM
If call the poison control center. They are pretty knowledgeable about this sort of stuff. Not to be alarming but they can answer questions.
View BurlyBob's profile
BurlyBob
5491 posts in 2262 days
#2 posted 07-10-2015 03:53 AM
Chris, the only way I’d use PT lumber in a basement was if it was in contact with bare concrete. It’s got to be the worst wood in the world for anything other that a barrier between concrete, dirt or gravel. I’ve finally gotten rid of all I had hanging around.
View JADobson's profile
JADobson
1034 posts in 2107 days
#3 posted 07-10-2015 12:22 PM
Code in my area requires you to use treated lumber for the bottom plate when framing basements. I would imagine that if there were significant health risks this wouldn’t be the case.
-- No craft is very far from the line beyond which is magic. -- Lord Dunsany
View bondogaposis's profile
bondogaposis
4725 posts in 2348 days
#4 posted 07-10-2015 02:00 PM
The saw dust is what I would be concerned about. Why not just buy some non treated lumber for your project?
-- Bondo Gaposis
ChrisBarrett
#5 posted 07-10-2015 02:04 PM
Yeah I found the MSDS for it, and the lumber itself doesn’t offgas or anything. So the biggest risk of having it inside would be in case of a fire. However, I think that the fine dust put into the air inside is probably the worst part of working with this stuff.
View bonesbr549's profile
bonesbr549
1546 posts in 3063 days
#6 posted 07-10-2015 02:11 PM
Like others said, in a basement where ground contact is made, you are requred to use treated in construction. While you do not want to breath a lot of it, I doubt it will be an issue. If the lumber is from china all bets are off!
ChrisBarrett
#7 posted 07-10-2015 02:12 PM
Bondo, yeah I am going to. I just used this because it was the only 2×8 that I had. I did not realize it was PT. I never would have cut it up inside if I knew that were the case. This stuff is not green at all, the only thing that gave it away eventually was the fact that it was too dense feeling.
View ToolAnimalAmos's profile
ToolAnimalAmos
15 posts in 1085 days
#8 posted 07-10-2015 07:51 PM
Most everything in your house is going to be toxic when it burns…Just saying.
The dust may be troublesome but seeing as its done Theres not much to worry about at this point. People survived lead paint, lacquer paint, and the 80’s. Im sure you’ll survive one 2×8
-- Fingerlakes farming and woodworking.
ChrisBarrett
#9 posted 07-10-2015 08:47 PM
I have to say though, I barely survived the 80’s :-D
View SCOTSMAN's profile
SCOTSMAN
5849 posts in 3582 days
#10 posted 07-10-2015 10:26 PM
Good God Chris ! Do you mean to say you are now in your Nineties. ?
Wow your nearly as old as our very ,very ,ancient but still living ,and extrmely Big and numerous Diamond type rich. All thanks to us vote-less fools Queenie Elizard berf LO L Alistair
ChrisBarrett
#11 posted 07-11-2015 04:32 AM
I suspect that the Scotsman said something funny, but I can’t figure what…
View Dark_Lightning's profile
Dark_Lightning
3159 posts in 3105 days
#12 posted 07-13-2015 02:16 AM
How many cuts did you make? You could try to quantify how much dust was generated. 10 cuts with a 1/8” kerf in a 2X8 is 1.625X7.25X.125, about 1.5 cubic inches. Then find out from the manufacturer how far the treatment penetrates into the wood, and what the percentage is (going to be really, really low). Tell the manufacturer what you did; they should also be able to ballpark how much hazardous material was generated. Then you need to calculate how much of it is actually ingested. This will be microscopic with respect to the amount generated, unless your basement air is exchanged with your house air on a regular basis or you are eating the sawdust. My first order of magnitude guesstimate is that you don’t have a problem, based on the amount generated (if you only made 10 cuts), and that a minimal amount of the dust got into the rest of the house. But if I did something like that, I’d wet mop rather than sweep and vacuum the dust, just because I’m that anal.
-- Random Orbital Nailer
skatefriday
#13 posted 07-13-2015 03:14 AM
The dust may be troublesome but seeing as its done Theres not much to worry about at this point. People survived lead paint, lacquer paint, and the 80 s. Im sure you ll survive one 2×8
- ToolAnimalAmos
Hey there, watch it with the 80s bashing.
The 80’s delivered us from the evil that was
bell bottoms and shirt collars wider than the Mississippi.
We also got U2, The Smiths, and Depeche Mode from the
80s. None of which are as toxic as lacquer.
ChrisBarrett
#14 posted 07-13-2015 03:37 AM
Dark, thanks for the response. I was thinking about it – calling them. But mostly just for future knowledge. I vacuumed everything up with my hepa vac (a real hepa vac, EPA certified) and then wiped all the machines down with simple green. I’m sure it’s fine, but I usually just try to be as safe as I can.
ChrisBarrett
#15 posted 07-13-2015 03:38 AM
And it probably was 10 cuts in total, both rip and cross cuts.
