| Forum topic by flyforfun | posted 49 days ago | 320 views | 0 times favorited | 12 replies | ![]() |
49 days ago |
I have built a lot of doors, this past year our small family shop built 8 kitchens (our 1st year) and we don’t outsource the doors. My observation has been we have no issues with cupping or twisting when using glued up raised panels. But when the cabinet is 42” upper and it is flat panel, I find when I rip my stile 2 3/8”, it has more of a tendancy to cup and over 42” will be more noticeable. Plus, since the flat panel is not ridgid, it will not straighten the stile out whereas a flat solid stock raised panel will straighten the stile presenting no real issues. So this is only an issue with flat panel doors on 42” uppers and not all of the doors have this issue, but many seem to to some extent. I typically will try to make adjustments in my hinges to accommodate as much as I can. Also, and this may be my issue. I don’t own a jointer and I don’t face joint my lumber. I buy 13/16” straight lined and planed 2 sides. I have thought of buying 15/16” and using my DW735 to flatten the wood but I am not sure that would help. Plus it would be very time consuming, very loud… Any suggestions? Jerry -- Jerry Nettrour |
