1/2HP Baldor Dust Collector
Forum topic by jayvansickle posted 07-09-2015 05:57 PM 698 views 0 times favorited 7 replies Add to Favorites Watch
View jayvansickle's profile
jayvansickle
25 posts in 1250 days
07-09-2015 05:57 PM
Not sure if this is the correct forum. Having lost a lung to cancer last year this a safety item to me. Evidence proves that sawdust is a carcinogen. I presently own a 1/2 horsepower Baldor portable dust collector. My question is: My shop is 24 X 24. I am going to run 4” sewer and drain pvc with 6 drops to assorted equipment. Will this collector be able to do this? Do I need more horsepower? I have roughly figured it will have about 36’ of pvc.
-- If a parsley farmer goes broke, can they garnish his wages
7 replies so far
View dhazelton's profile
dhazelton
2789 posts in 2471 days
#1 posted 07-09-2015 06:10 PM
I am no expert and have never set up a system but I would guess that yes, you need more horsepower. I just got a 1 hp Delta and it says to not exceed ten feet of hose. With what you want to do I would assume 2 hp or more.
View AZWoody's profile
AZWoody
1411 posts in 1398 days
#2 posted 07-09-2015 07:38 PM
With your health issues, I would not trust 4” to do the job in getting the worst part of the dust out.
You’l be able to get the larger chips and debris, but not the fine dust that causes the health problems.
Realistically, you’d need at least a 3hp motor and 6” ducting.
View Redoak49's profile
Redoak49
3597 posts in 2163 days
#3 posted 07-10-2015 01:32 AM
I agree you need more hp. However, with your medical condition, I would also look into a dust mask rated N100. In addition, I would find somebody trained to fit a mask. Or, you could use a Trend Air Shield
Good Luck
View Dabcan's profile
Dabcan
255 posts in 2845 days
#4 posted 07-10-2015 01:41 AM
My shop is the same size and about the same number of machines. I would try to reposition your machines to reduce the length of pipe, either that or have two dust collectors to reduce the length. I would go with a 2hp machine, and on top of that a mask is always good. You should also get an air cleaner to hang from the ceiling to pick up the fine particles.
-- @craftcollectif , http://www.craftcollective.ca, https://www.etsy.com/shop/craftcollective?
View Andre's profile
Andre
2138 posts in 1980 days
#5 posted 07-10-2015 03:33 AM
- Dabcan
Same as my shop 24’ by 24’ with 10’ ceilings, I have a general 2 hp DC unit and ran everything in 4” PVC. I run my tablesaw and 6” jointer through a Veritas cyclone and do need to improve the seal somehow, but if the drum is empty she sucks great! Also put the small Grizzly filter up on the roof and was surprised at how fast the filter gets dirty! I picked up a anemometer before I started and the air flow increased after the unit was hard piped.
AZWoody
#6 posted 07-10-2015 03:56 AM
- Dabcan
Same as my shop 24 by 24 with 10 ceilings, I have a general 2 hp DC unit and ran everything in 4” PVC. I run my tablesaw and 6” jointer through a Veritas cyclone and do need to improve the seal somehow, but if the drum is empty she sucks great! Also put the small Grizzly filter up on the roof and was surprised at how fast the filter gets dirty! I picked up a anemometer before I started and the air flow increased after the unit was hard piped.
- Andre
If your hanging filter gets dirty fast that means you’re breathing those particles as well. The dust collector, if set up the right size and cfm, will get most of that before it’s in the air. Overhead filters do a good job of helping to show what you’re breathing in or to help clean the air after you leave the shop.
jayvansickle
#7 posted 07-10-2015 04:11 AM
- Dabcan
I already purchased 4” sewer and drain pipe and fittings. The 90 degree will be two 45’s with a 12” piece of pvc between them. All the drops will be “Y” fittings. I guess I need to look at a new dust collector system. Thanks for the info. Never thought of air cleaner.
