How to: Resaw without a bandsaw
Forum topic by Zuki posted 793 days ago 2502 views 0 times favorited 21 replies Add to Favorites Watch
View Zuki's profile
Zuki
1230 posts in 975 days
793 days ago
Topic tags/keywords: resaw
In making the cabinet for DW I required some ¼” board to fill in the back panels for the doors. The only problem is that I do not have a band saw and I only have 1” board to resaw. What is a fella to do?
My process:
I cut the boards a little long and jointed both edges (using my router) as they will be running on the table saw. [no this is not the actual board I used . . . just for illustration purposes :) ]
I roughly marked the center of board as a guide for the table saw. I split this mark with the blade. I also marked one face of the board as a reference side.
When I set up the TS I used two featherboards. This kept the board tight againt the fence as it entered the blade and as it left the blade. I cut the board in four passes – 2 with the blade at ½ height and 2 with the blade at full height. I made sure to leave at least ½” holding the boards together. Next time I will put on a taller fence and taller featherboards.
NOTE: make sure that on all 4 passes through the blade the board’s reference side is aginst the fence. If not, your gonna results that you may not be happy with.
When the board was cut it was off the wood vice and a handsaw. My handsaw was less than sharp so it took a little longer than expected to remove the waste.
When the boards were separated it was off to the planer to finish up with the final product.
I am quite happy with the results.
3053 posts in 919 days
793 days ago
You got a very nice result given the obstacles you faced.
There is certainly nothing wrong with using a good set up to resize lumber.
It’s not substitute for a decent bandsaw as the BS can slice em off like strips of bacon with little effort.
I can certainly applaude your efforts to move forward with a limited arsenal of tools and you got the right result which is all that counts.
View Mark Geserick's profile
Mark Geserick
22 posts in 848 days
793 days ago
And I thought I had to spend big bucks to purchase a band saw…I’ll give it a try.
Mark
-- Mark, South Jersey
View mot's profile
mot
4903 posts in 934 days
793 days ago
Nice result. I’ve seen this method and it always gave me a bit of pause. It looks like it did the trick!
25806 posts in 1298 days
793 days ago
Great job. I’ve never tried that way to get thin wood. I’ve always had a bandsaw even before I knew that I needed thin wood.
But I now use it all the time for resawing and cutting tenons on boards.
View Dadoo's profile
Dadoo
1723 posts in 888 days
792 days ago
Nice post Zuki! I’ve done this before as well, and it works real good. Try adding a board, or piece of metal to “raise your fence height” which would stabilize the top as it passes thru the blade.
View TomFran's profile
TomFran
2515 posts in 892 days
792 days ago
Zuki,
This is pretty cool. Did you do this with “Sketchup?”
View Buckskin's profile
Buckskin
484 posts in 886 days
792 days ago
Zuki, I have been thinking on how to do this for quite a while. I have had mixed emotions on using the table saw. But know that I see your efforts I I think I can, I think I can. Great Post!
View Calgirl's profile
Calgirl
188 posts in 793 days
792 days ago
Maybe I’m too safety concious (if there is such a thing), but this process seems very dangerous to me. To use the TS in this manner requires that you have a lot of control of the piece being sawn. A tall fence to be certain that the wood does not torque on you during the cut would help. If you tried to do this with a piece of wood that was a little thinner and/or narrower, you’d be in big trouble, I think. If the portion of the stock which is uncut (the part that must be sawn by hand later) is thin, this will allow the blade to bind and who knows where the stock would be thrown. Some kind of ingenious jig might help as long as everything is held secure both beside and above the blade.
-- Forget the health food, I need all the preservatives I can get !
View David's profile
David
1982 posts in 1037 days
792 days ago
Zuki -
Excellent blog entry!
View Zuki's profile
Zuki
791 days ago
Thanks all. I hope it helps other people with the same problem . . . lack of equipment. I consider I saved myself $500 from not having to buy a Band Saw (although one may be in my future).
Binding was a concern. Next time for an added measure of safety I will:
- add a taller fence
- may use taller featherboards
- use shims and clamps in the opening NOT being cut to ensure the board does not bind on the blade
I would not attempt resawing anything less than 1” as a 1” board – 1/8” blade = 2 boards @ 7/16. Planing would bring you down to 1/4” thickness.
I did indeed use Sketchup and then inported it into Paint for the text.
View jockmike2's profile
7352 posts in 1144 days
791 days ago
Thats using the ole noggin Zuki. Good for you. I’ve done it before too. But not as safe as you. Good job. mike
-- Mike. mwurm13@yahoo.com
View che's profile
che
123 posts in 924 days
791 days ago
I’ve done this and would recommend having a tall fence and tall feather boards (Zuki’s looks fairly tall already) I would also recommend NOT using the outfeed feather board. At best nothing will happen, but you’re likely to burn the wood if the outfeed feather board pinches the wood and at worst case it will pinch and throw the wood back at you. Another trick (for longer boards) is to have an assistant pull the board from behind the saw once its clear of the back of the table. It’s the safest place to be and you don’t have to worry about when the blade is going to poke out the back of the board. A good feather board will keep the board against the fence.
A feather board similar to the Grip-Tite would work well.
-- Che.
View bryano's profile
bryano
546 posts in 831 days
791 days ago
Nice points che. the first time i did a resaw on the TS I burned a nice piece of cherry.
-- bryano
View Dustmite97's profile
Dustmite97
182 posts in 118 days
67 days ago
Looks like it worked very well. I am going to give this method a try.
-- Remember, measure twice, cut once
View RetiredCoastie's profile
RetiredCoastie
239 posts in 81 days
67 days ago
Nicely done. You should consider using a zero clearance insert.
-- Eagles may soar, but weasels don't get sucked into jet engines! Mike D.
View Betsy's profile
Betsy
2386 posts in 794 days
67 days ago
I’ve used this method a ton of times with no problems. Use a tall fence, a feather board in front of the blade (I’d also ditch that second feather board) and small cuts. And as you did, I always leave a strong 1/4” or so in the middle and cut that with a hand saw. I have never used shims and don’t think they would be necessary if you leave enough wood uncut.
I also would not recommend it for anything less than a 1” board.
This method does waste a lot of the board, but if you don’t have a band saw – and don’t want to try your hand at hand resawing – it’s a good method.
Certainly a method to consider.
View Zuki's profile
Zuki
66 days ago
I have since bought a band saw so I have retired this method.
Funny thing is that I have yet the need to resaw anything. :-)
View reggiek's profile
reggiek
716 posts in 168 days
66 days ago
I have had to use my TS on occassion when the Bandsaw was not up to snuff….I would highly recommend though that if you use your TS…install the riving knife (I would not use the TS with just a saw blade and no guard) ....without one…you run a serious risk of kickback…and possible serious injury. If your saw does not have a riving knife…then I would recommend having someone with one/or bandsaw or a lumberyard make the cut for you.
Glad to hear you got a BS though now….be careful at all times…I don’t think any of us want to read about one of our good friends getting injured or worst of all killed by an accident that could have been avoided.
View stefang's profile
stefang
1655 posts in 232 days
65 days ago
No comment on the safety aspects Zuki, but I do think it was a darn good blog. Congrats on you bandsaw puchase. Your life will now be simpler.
-- Mike, American in Norway
View russv's profile
russv
71 posts in 67 days
62 days ago
i have resawn both ways and I like the TS method. If you want you can still final cut on the band saw and it is a lot easier. If you have a thin kerf TS blade, it makes the cuts go better also.
russv
-- yknotwood.com: where to go because you don't want no stinking plastic!
17022 posts in 475 days
62 days ago
Hey Guys
I just saw Roy do the same thing with a hand saw , The old fashion way. Good blog I agree with the taller fence for sure and smaller increments. You need to very careful any time you have you saw blade cranked up that high. I also like to put a shim in the side not being cut just to avoid the wood from pinching the blade.
-- Jim from Heirloom Woodshop, custom furniture maker, woodworking school, heirloomwoodshop.com
