Need to waterproof wood for constant exposure.
Forum topic by mahdee posted 07-08-2015 02:28 PM 1132 views 0 times favorited 24 replies Add to Favorites Watch
View mahdee's profile
mahdee
3883 posts in 1763 days
07-08-2015 02:28 PM
Topic tags/keywords: tip trick question
Hi fellas,
Is there a way to use something like fiberglass tape and glass resin to waterproof a wood cavity so it will indefinitely hold stagnant or running water?
Thanks
-- earthartandfoods.com
24 replies so far
View rwe2156's profile
rwe2156
2924 posts in 1476 days
#1 posted 07-08-2015 02:30 PM
What’s it for?
I know shower liners are designed for this type thing.
There is a glue you can seal the seams with.
mahdee
#2 posted 07-08-2015 02:31 PM
I should mention that I want to create a barrier between the wood and the water and not necessary “waterproof” the wood itself. Also, I would I prevent the barrier from sweating?
mahdee
#3 posted 07-08-2015 02:33 PM
rwe2156, It is an irregular cavity in the wood that will be filled with water.
View jmartel's profile
jmartel
7884 posts in 2146 days
#4 posted 07-08-2015 02:35 PM
Yes, they do that on wooden boats quite frequently.
mahdee
#5 posted 07-08-2015 02:38 PM
jmartel, Resin and tape?
jmartel
#6 posted 07-08-2015 02:54 PM
Yes. Just as you would for fiberglassing anything else. More like fiberglass cloth/weave, but you might be able to get away with tape.
Just don’t use the fiberglass matting that looks like a bunch of strands stuck together. That stuff is awful to work with. Get a woven mat.
mahdee
#7 posted 07-08-2015 02:58 PM
Thanks a bunch. Yes, I have seen the cloth. It appears to be a lot more flexible.
View hotbyte's profile
hotbyte
991 posts in 2971 days
#8 posted 07-08-2015 03:20 PM
Search Google for West System fiberglass and/or epoxy.
View bigblockyeti's profile
bigblockyeti
5112 posts in 1716 days
#9 posted 07-08-2015 03:33 PM
Would a small plastic pond or a flexible pond liner membrane work for your application?
View Woodknack's profile
Woodknack
11610 posts in 2376 days
#10 posted 07-08-2015 05:03 PM
I watched a show on building wood canoes and they glassed the bottom, you could see the wood right through it.
mahdee
#11 posted 07-08-2015 05:30 PM
bigblockyeti, I don’t think that would work for this project unless I could melt the plastic. Rick M., that is exactly what I want and I think the west system will do that. The price is a shocker for sure. Amazon is advertising another similar product a little less with good review and they have some that is penetrating kind (bit more expensive though).
Woodknack
#12 posted 07-08-2015 06:58 PM
View shipwright's profile
shipwright
7980 posts in 2794 days
#13 posted 07-08-2015 08:58 PM
You can use epoxy and cloth (6oz) and it will be fine. If you use polyester resin (fibreglassing resin) .... It won’t, at least not for long. Depending on the application, epoxy alone could also work. I have made plywood fuel and water tanks this way ….. and a bath tub.
mahdee
#14 posted 07-08-2015 11:52 PM
Cool video Rick. Thank you.
Paul, thanks the conformation. I ordered the cloth and the epoxy. Now all I need to figure out is how to execute what is in my head. Thanks a lot for the inputs.
View BryanoFLA's profile
BryanoFLA
5 posts in 1030 days
#15 posted 08-09-2015 12:59 PM
I’ve made plywood aquariums before. Check this out.
https://www.youtube.com/watch?v=cdyANDq_x_s
