a simple jig for cutting panels
Forum topic by Bob #2 posted 2061 days ago 654 views 0 times favorited 8 replies Add to Favorites Watch
3808 posts in 2187 days
2061 days ago
Topic tags/keywords: circular saw panel jig angled cuts
I came across this method of skidding a circular saw a few years back and have used a 50” and a 98” jig since then for knocking down sheet stock without too much trouble.
One day I was faced with a nasty cut on an angle that had to be relatively accurate and I decided to use this slider again.
As you can see I set the board in place with C clamps and just push the saw along the straight edge and on the masonite backing. ( the c clamps are modified with round wood handles making them easier to set.
It’s the easiest solution I have found.
I know you can buy the aluminum rails for this but they dont support your saw on a smooth surface the way this does.
ps. You can lay out a 2” sheet of styrofoam on your saw table top to cut against so the blade will clear the table . A $10.00 sheet will last a long time
Enjoy
panel-sled
8 replies so far
View mot's profile
mot
4912 posts in 2202 days
#1 posted 2061 days ago
Nice! In my father’s shop there is an old plywood jig of the same design that he’s been using since I was a sparkle in my mamma’s margarita.
View WayneC's profile
WayneC
9596 posts in 2263 days
Great jig Bob. Thanks for sharing.
View Tony's profile
Tony
974 posts in 2196 days
#3 posted 2061 days ago
Nice one Bob – I was using this method for a long time, until I got my Festool Circular saw – Now I use their jig, but it on the same priniciple – only costs more!!!!!!
PS. Answered your question about the stools by the way
View Thos. Angle's profile
Thos. Angle
4400 posts in 2128 days
#4 posted 2061 days ago
Yep, got one 8 feet long and one 56” long. Never far away.
#5 posted 2061 days ago
The reason I brought it up again was for the younger gals and guys who hav just joined us.
A simple thing like this is often the difference between enjoying this craft or giving it up.
I’m hoping it helps out someone.
Us older doods need somebody to find ours for us. <g>
View Bob Babcock's profile
Bob Babcock
1804 posts in 2252 days
#6 posted 2061 days ago
A tried and true idea for sure. We should certainly share even those ideas that have been around for awhile. I’m sure there are many things a lot of you think nothing of that I would think was a neat idea. Jigs especially.
Douglas Bordner
3907 posts in 2229 days
#7 posted 2060 days ago
I have always just flopped the big styofoam sheet on the garage floor. Duh. I’m sure I wouldn’t have had to crab around on the concrete if I had put my mind in gear before engaging the saw trigger finger. Sometimes we (relatively) younger dudes need a hand from you “older doods” when the issue is common sense.
Thanks for the tip, Bob.
View ernieb's profile
ernieb
17 posts in 2090 days
#8 posted 2044 days ago
made one of these 3 years ago. what a great and simple idea. i now have several lengths and even use a router for dadoes. just goes to show that some of the best ideas are the simplest ones.
-- ernieb westerlo, ny
