Cutting a straight line
« back to Scrollsawing forum
Forum topic by Edwin posted 07-08-2015 01:04 PM 910 views 0 times favorited 4 replies Add to Favorites Watch
View Edwin's profile
Edwin
143 posts in 3238 days
07-08-2015 01:04 PM
Topic tags/keywords: shaping
I just started a project that requires me to cut out some windows that have to be straight. It is Toys and Joys pattern 126 Hydraulic crane. If you look at the pattern I am cutting the windows of the cab. Ed
-- Ed Port Republic
View BinghamtonEd's profile
BinghamtonEd
2298 posts in 2609 days
#1 posted 07-08-2015 01:44 PM
Don’t know how thick your material is, so I’m not sure if a router and flush trim bit would be applicable? If not, scrollsaw or fret saw close to the line and then file it to finish?
View lew's profile
lew
12510 posts in 3995 days
#2 posted 07-08-2015 01:52 PM
Maybe build a “pattern” from straight pieces- to form an opening- then do what Ed suggested with a small trim router and a bearing bit.
Of course, if you would like to buy a new toy- a Laser Cutter would be perfect for this!
View hotbyte's profile
hotbyte
991 posts in 3215 days
#3 posted 07-08-2015 02:01 PM
How many do you plan on doing? If just this one build, the scroll saw/fret saw/jig saw option and filing/sanding to line might be best.
If you are going to crank out 3, 4 or more of the toys, a pattern and trim router sounds like best option. You would still cut with some type of saw close to the line and then use the pattern/router.
I do like the laser cutter idea :) Always look for projects requiring new, cool tools :) :) :)
View CueballRosendaul's profile
CueballRosendaul
484 posts in 2380 days
#4 posted 07-09-2015 03:16 AM
I’d use a scroll saw. Keep in mind that you can always clamp a straight edge to the table of a scroll saw and get a very crisp line if you go slow. You might also need to score the line with a knife first which will prevent tear out.
If you don’t have a scroll saw, here’s what I told a new woodworker a few weeks ago during his visit to my shop. I said, ”you don’t need to own all these tools…you just need to add beer to the shop fridge when you come over to use them.”
-- Matt CueBall Rosendaul. I don't think I've ever had a cup of coffee that didn't have cat hair or sawdust in it.
