Tolerance levels you build to?
Forum topic by InstantSiv posted 07-08-2015 06:17 AM 1468 views 0 times favorited 29 replies Add to Favorites Watch
View InstantSiv's profile
InstantSiv
262 posts in 1588 days
07-08-2015 06:17 AM
Topic tags/keywords: question joining milling
Just curious what tolerances everyone out there builds to.
I’m 1/8th German and I swear it comes screaming out when I measure and cut because I sit there and try to get each cut dead on. I’m talking about 1/64th or better. As I do more and more I’m figuring out that I can get by with 1/8” sometimes and figuring ways where exact lengths and consistency can be irrelevant to quality when the item is finished.
In other words… how an@l are you?
29 replies so far
View rwe2156's profile
rwe2156
2916 posts in 1474 days
#1 posted 07-08-2015 10:04 AM
Thats funny because I’m like 3/4 German and I have to fight the same thing.
1/64th is probably my limit in cutting something to length, but when doing joinery you can get out the feeler gauges because I’m down to the thousandths.
I read the human finger can sense discrepancies down to about .0005 or something so thinking about it, when a joint is flush enough to satisfy me, its probably at .0005 or below.
Does that make you feel better?
......or worse? ;-)
Seriously, I think having matching parts the exact same length is way more important than the actual measurement, so I concentrate more on consistency by using stop blocks, etc.
Everything else I don’t worry about I just flush up with hand planes, scrapers, etc.
View bigblockyeti's profile
bigblockyeti
5111 posts in 1713 days
#2 posted 07-08-2015 11:19 AM
For me it really depends on the project. If it’s cutting dovetails or picture frame miters it really does need to be dead on. If building picnic table from pressure treated pine or cutting white oak planks for a trailer deck, those kinds of projects tend to be a little less demanding from a tolerance standpoint.
View BinghamtonEd's profile
BinghamtonEd
2298 posts in 2362 days
#3 posted 07-08-2015 11:28 AM
- bigblockyeti
I agree with this. It also depends on what aspect of the project you’re working on. Example…If I’m making a frame & panel door, I’ll be picky about the frame. Make sure all of the rails/stiles are perfectly flush with each other, the tenons fit well so that the shoulders close up at the same time the haunch does and it’ll stay together without glue, but come apart with just hand pressure. Then, when I go to cut the solid panel to size, since it needs some room to move in the grooves, within 1/16 is fine. But as far as cutting the frame parts to length/width, I shoot for around 1/64. I’m more concerned with the consistency between the pieces, rather than how they compare to the tape measure.
View JoeinGa's profile
JoeinGa
7736 posts in 2000 days
#4 posted 07-08-2015 12:55 PM
Wait … what?
You mean ”Close enough is good enough” DOESN’T work in woodworking ??
Oh my :-)
View Earlextech's profile
Earlextech
1161 posts in 2683 days
#5 posted 07-08-2015 01:05 PM
For me it really depends on the project. If it s cutting dovetails or picture frame miters it really does need to be dead on. If building picnic table from pressure treated pine or cutting white oak planks for a trailer deck, those kinds of projects tend to be a little less demanding from a tolerance standpoint.
- bigblockyeti
I agree with yeti. My Father in Law (1/2 German) worked to 1/128” which drove me nuts when I worked with him. As a cabinetmaker, 1/32” tolerance is just fine, but if I’m building a 18th century highboy, I would be less tolerant!
View jeffswildwood's profile
jeffswildwood
3180 posts in 1970 days
#6 posted 07-08-2015 01:09 PM
It seems the more I do wood work, the more strict I become. When I first got back into it, 1/8-1/16 I was OK, upset, but OK. Now I get real upset with 1/32-1/64, and not OK. Don’t even get me started with the square! I have some serious issues with it!
-- We all make mistakes, the trick is to fix it in a way that says "I meant to do that".
View Nubsnstubs's profile
Nubsnstubs
1286 posts in 1723 days
#7 posted 07-08-2015 01:52 PM
I guess being a Cajun doesn’t really count in close tolerances, but as a youngster, I was told that “paint and drywall will cover it up.” Later in life, I always held 1/32”, but then, with the use of a good accurate slide-board and stops, the same dimension for each piece was more achievable than trying to get the exact dimension by marking and cutting each piece. We all have to remember that wood moves. Today you can have your exact dimension, but tomorrow with increased humidity, it’s going to be different than yesterday. ............ Jerry (in Tucson)
View Woodknack's profile
Woodknack
11600 posts in 2373 days
#8 posted 07-08-2015 07:09 PM
I never think in terms of tolerances, I shoot for dead on. Most of the time precision trumps accuracy anyway.
View Ripthorn's profile
Ripthorn
1458 posts in 2978 days
#9 posted 07-08-2015 07:22 PM
Most of my projects are guitars, so I hold very close tolerances. I have some metal working machinery for the machining I do, and it gets used for wood not infrequently. Then again, I’ve got a couple degrees in physics and look at the engineers like they’re the sloppy ones, so I may be an outlier. I say, whatever you’re ok with is ok. No need to worry about what others think. I have to remind myself that some super minor discrepancy will be ok and not to lose sleep over it.
View HornedWoodwork's profile
HornedWoodwork
222 posts in 1207 days
#10 posted 07-08-2015 07:29 PM
I get it close and close it with handtools to get a perfect fit. I can’t be bothered to knock it dead off the machine, the setup is laborious and not very fun. I always rough it (I mean within say 1/8th or 1/16th) and always fat. Then I close. The only time this is not true is when I am crosscutting endgrain. I take the time to get that precise becuse it doesn’t close well with handtools. I also try and leave very little chance of error by removing as many obstacles to say, a joint closing, as possible. I find that I work very quickly in this way and I’m not having to get nitty-gritty measurements and trying to nail them perfectly off the saw/router, whatever.
-- Talent, brilliance, and humility are my virtues.
View MrRon's profile
MrRon
4757 posts in 3236 days
#11 posted 07-09-2015 05:51 PM
I work to machine shop tolerances. If I shoot for.002”, I know I will not achieve it, but I will be a lot closer than if I were working to a 16th or a 32nd. It really boils down to what measuring tools you have available. It is just as easy to make a mark using a vernier caliper as it is with a tape measure.
rwe2156
#12 posted 07-09-2015 06:44 PM
HornedWW – right on!
MrRon – to each his own, but in ww’ing rarely does a piece need to fit that accurately.
View JayT's profile
JayT
5619 posts in 2204 days
#13 posted 07-09-2015 07:02 PM
- InstantSiv
Depends on the time of year. During summer I’ll build to about 90 degrees. At that point it’s too hot for me to tolerate anymore. :-)
View WoodNSawdust's profile
WoodNSawdust
1417 posts in 1169 days
#14 posted 07-09-2015 07:07 PM
Many years ago I was told that I should always work to the tightest tolerance I could. If I did that with everything I would never be in a situation where I was not accurate enough and I would never have to stop and ask myself how accurate I need to be.
I try to work to a 1/64 inch.
View Hammerthumb's profile
Hammerthumb
2844 posts in 1968 days
#15 posted 07-09-2015 09:55 PM
- InstantSiv
Depends on the time of year. During summer I ll build to about 90 degrees. At that point it s too hot for me to tolerate anymore. :-)
- JayT
I can work to about 105 degress, then my ac can’t keep up!
-- Paul, Las Vegas
showing 1 through 15 of 29 replies
