4" disk
Forum topic by Partridge posted 52 days ago 303 views 0 times favorited 12 replies Add to Favorites Watch
View Partridge's profile
Partridge
221 posts in 854 days
52 days ago
I amt trying my hand at making a drum sander and Iam have trouble cutting disk with band saw jig.
1/4 blade.
3/4 sawdust board
center hole 5\8
the blade just wanders and wants to bind.
is there a better way
-- Do it right the first time. Becuase fixing it is a wast of time.
View mski's profile
mski
360 posts in 878 days
52 days ago
I have that trouble too, the blade’s cutting edge has to be aligned with the center pivot point of the jig,
I could never get consistent circles so I scrapped it and use my router with a home made circle jig, perfect circles with no saw marks, hope this helps.
-- MARK IN BOB, So. CAL
View lew's profile (online now)
lew
4504 posts in 653 days
52 days ago
Move the jig so the leading edge of the teeth are on a line with your pivot pin. That should solve the binding problem. Somewhere I saw a chart that had a 1/4’ blade should be able to cut a 3/8” radius- that was probably the absolute smallest.
A wondering blade might mean that the tension on the band saw blade is not sufficient.
View papadan's profile
papadan
478 posts in 266 days
52 days ago
I am planning on using a 4”hole saw when I start building my drumm sander. The 1/4” pilot drill will aid in drilling the larger center hole also.
-- Dan-- Info for all @ http://www.hoistman.com
View Kent Shepherd's profile
Kent Shepherd
839 posts in 184 days
51 days ago
I agree with papadan, except to get a 4” disc, you need a larger hole saw. The 4” is the outside diameter of the hole saw, which will be the size of the hole you cut. To get a 4” disc, you will need a 4 1/8” or maybe 4 1/4” hole saw.
View dbhost's profile
dbhost
624 posts in 130 days
51 days ago
Got lathe?
-- Trying to follow the example of the master.
View Mark's profile
Mark
206 posts in 172 days
51 days ago
im with mski…the holesaw does work but if you dont have that big of a hole saw jig up your router to cut a radius around into a full circle…makes perfect edges with no bumps to worry about or sanding to do.
-- Every woodworker cuts a finger off atleast twice in their life! Mark, Windsor, Ontario
View Vincent Nocito's profile
Vincent Nocito
158 posts in 262 days
51 days ago
Try a circle cutter with the blade turned to pruduce a flat circle instead of a wheel profile. I used this to make a laminated drum as part of a toy train many years ago. Use a drll press and slow the speed to about 250 rpm.
View Jim Crockett's profile
Jim Crockett
328 posts in 631 days
51 days ago
Draw the 4” disk with a compass. Using a jigsaw, cut close to the line – don’t worry if it isn’t very even. Drill a 1/4” hole in the center of the circle – use the hole made with the compass as a pilot. Insert a 1/4” bolt, with washers, and tighten down with a nut. Insert bolt end in your drill or drill press. Hold a sanding block to the edge until you have a 4” diameter circle.
JimC
Partridge
49 days ago
you all have good ideas thank you…
I thought of the hole saw and circle cutter and this would do the job well. but ass i thought about next step i realized i know have a 1/4 hole in the center and i need it to be a 5/8 hole. there is only one kind of bit that i know of that will chase that hole. I do not have this bit and on pricing this out it was going to cost 20 to 30 bucks.
The lathe is and idea that i will try next. i was thinking of gluing 8” up at a time.
Jim , this system work but you have to be care full you do not oval the peace. 21 would take some time but it could be done.
View stefang's profile
stefang
1655 posts in 232 days
49 days ago
The lathe is a good idea, but it could be a little difficult getting a consistent diameter unless you are very careful and check your progress often.
-- Mike, American in Norway
View UnionLabel's profile
UnionLabel
149 posts in 98 days
49 days ago
You can still rebore your hole in your 4” circles after leaving a 1/4” hole behind. Just glue a dowel in the hole, cut off flush and redore with a 5/8” spade bit. you only need enough to get the bit centered and started.
-- Easy Peasy Lemon Squeezy-May all your dovetails fit tight and right the first time
View firecaster's profile
firecaster
482 posts in 316 days
48 days ago
If you can get them cut close to the line; after assembly put a sandpaper covered piece of plywood on your sander bed and lower the turning discs (drum) to it. Sanding them all at the same time. They will be exactly the same diameter.
-- Father of two sons. Both Eagle Scouts.
