I'm wondering if anyone uses a small (6 gallon, 2.5 cfm) compressor with their air sander? . I have the compressor, and am thinking of buying the Harbor Freight sander (gets good views) , which runs at 7cfm. does this mean I need to stop sanding every 10 seconds or so? I've also seen an Eastwood sander online that runs at 2.5cfm,but havent seen any reviews.
It has been years since I worked in a shop that used air tools. If I remember correctly the rule was that the sum of all tool's CFMs had to be less than the CFM of the compressor. So, in a single user shop CFM of tool <= CFM of compressor.
That said, I suspect that you could use the tool for short periods of time with the performance of the dropping as each period progresses.
You'll get a little run time, but plan on stopping frequently to let the compressor recharge. Unless you need to do very little sanding, the additional time required waiting for it to build pressure would be counterproductive.
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
