Failure analysis
« back to Woodturning forum
Forum topic by kmetzger posted 07-05-2015 05:48 PM 1255 views 1 time favorited 9 replies Add to Favorites Watch
View kmetzger's profile
kmetzger
157 posts in 2019 days
07-05-2015 05:48 PM
Here’s the result of my attempt to turn a square candle holder. I figured out how to mount it, but something went badly wrong. I mounted the square blank on a glue block, shaped the bottom and cut a 1 5/8” recess to fit my Nova pin jaws. Following these instructions https://www.canadianwoodworking.com/plans-projects/candle-holders I left about 1/4” uncut at the rim. I then reversed the blank and turned the inside. But instead of getting the flat wings I was trying for I got this: and this:
I would greatly appreciate your ideas on what I did wrong.
-- Kim, Ajijic, Mexico, http://tinyurl.com/7w5fm25
9 replies so far
View bondogaposis's profile
bondogaposis
5090 posts in 2552 days
#1 posted 07-05-2015 05:53 PM
You cut too deeply, thereby removing the wings.
-- Bondo Gaposis
View TheDane's profile
TheDane
5549 posts in 3864 days
#2 posted 07-05-2015 10:54 PM
Bondo Gaposis has it right … in these interrupted cuts where you are cutting air as well as wood, it is easy to get too aggressive. Don’t ask me how I know this!
kmetzger
#3 posted 07-05-2015 11:53 PM
On my third try I’m getting closer. But it still doesn’t look like Bob Hamilton’s even though I’m using the same size blank (well a little thicker – mine was 1 3/8” thick). The sides on the bottom don’t match the original that I’m trying to imitate.
View Steve Peterson's profile
Steve Peterson
394 posts in 3283 days
#4 posted 07-09-2015 11:36 PM
The 2nd one is looking better. Maybe cut a bit more off the bottom to get the center portion of the wings a bit thinner. I would take it over to the belt sander and lightly touch all 4 sides to sharpen the corners before finishing it.
-- Steve
View LeeMills's profile
LeeMills
618 posts in 1502 days
#5 posted 07-10-2015 02:43 AM
I am horrible at trying to explain anything but…Like Steve said, more off of the bottom. Both to get the wings thinner and to decrease the diameter of the bottom bowl shape which will make the wings more pronounced.
Bob, in his instructions about half way down said “Cut the rim to a consistent thickness. You can’t really see what is happening with the lathe running, so you need to stop the lathe frequently to check your progress.”
As well as stopping frequently it helps to have a neutral back drop. I use a shade but a piece of white poster board will work the same to seen the outline better while spinning. The wings can still be hard to see but at least there is not “clutter” behind to make it worse.
When you stop and check you can make a pencil mark on your tool rest to help show you where more attention is needed.
kmetzger
#6 posted 07-10-2015 02:52 AM
I finally made one that looks much more like Bob Hamilton’s. I had trouble visualizing the final shape. Bob sent me some videos and advice and things went a lot better. Here’s what Bob wrote: “It looks to me like you haven’t taken enough wood off. :D Once you have the outside shape the way you want it you have to turn the inside shape to the same profile in the areas where it is an interrupted cut in order for the rim to be a consistent thickness all the way around. In other words, as you cut the interior shape your gouge should be moving parallel to the outside surface. Once you have cut past the “square” and into the fully round area then the interior shape no longer has any effect on the rim and you can level back out and start to come back up to the candle hole.”
kmetzger
#7 posted 07-10-2015 01:24 PM
Resized photo.
LeeMills
#8 posted 07-10-2015 03:12 PM
I’m glad Bob Hamilton was able to put into words which for some (like me) is difficult to describe. Guess that why he is a good teacher.
View BurlyBob's profile
BurlyBob
5981 posts in 2466 days
#9 posted 07-10-2015 09:24 PM
Yours look pretty darn good. I think you did a really fine job. I know I could not do anything like that!
