Rockwell jointer guard return spring missing
Forum topic by RMI66 posted 07-05-2015 04:13 PM 899 views 0 times favorited 2 replies Add to Favorites Watch
View RMI66's profile
3 posts in 991 days
07-05-2015 04:13 PM
Topic tags/keywords: rockwell jointer guard spring spring supplier
I just picked up a Rockwell jointer Model 6 (P/N 37-608) and it’s missing the return spring for the blade guard. It’s a torsion spring and I can’t seem to locate a source for this. The Rockwell P/N for the spring is 418-09-122-0001. Any ideas on where I might find one? Thanks.
2 replies so far
6491 posts in 2133 days
#1 posted 07-05-2015 05:28 PM
If all you are missing is the spring, consider yourself lucky, as usually it’s the whole guard assembly that is missing! Check your local hardware store… My local Ace has a pretty good selection of springs and you can usually find one that is close enough to make work with a little creativity. Alternatively, they are pretty easy to make yourself (~19ga stainless steel wire should be sufficient).
PS: Stainless MiG welding wire works pretty good as well.
3 posts in 991 days
#2 posted 07-16-2015 01:55 AM
Mr. Unix, thanks for the comment. I tried to wind my own spring from music wire and it worked perfectly!
