| Forum topic by Thomas Keefe | posted 49 days ago | 296 views | 0 times favorited | 10 replies | ![]() |
49 days ago |
Topic tags/keywords: question oak finishing I am applying finish to a nightstand I built. It is made of white oak. I stained it and let it dry Tom |
49 days ago |
I’d take a scraper to it and redo. Should be an easy fix. -- You can't get a hug from Facebook. |
49 days ago |
Thanks. I will give it a try. Tom |
48 days ago |
Your hand must of been contaminated with something….. -- "Even small steps makes a distance." (Shawn Phillips, musician) |
48 days ago |
Hi notottoman. The wood had stain applied and then I applied the Waterlox. Perhaps the surface was Tom |
46 days ago |
Tom, From what I have read, I assume the Waterlox did not take to the area where the hand print is. The only fix is to sand, scrape or strip that shelf back to bare wood and re-stain and recoat with Waterlox. I think you will spend more time trying to repair this “spot” and it will never blend it in correctly (the stain). Benzene is an old term for Toluol or Toluene. A very strong solvent that will strip the stain below right off; you might also try mineral spirits or paint thinner, they remove hand oils, etc just as well. Hope this helps. |
46 days ago |
Hi Chip. Yes, it looked to me like the stain was fine but the Waterlox didn’t take. Thanks for the tip on the Benzene. I will avoid using that over the stain. It sounds like Thanks for the information. Tom |
46 days ago |
Thomas sorry i’m getting back to you this late…h2olox No malice or a confrontation is intended in this post…. ’-) -- "Even small steps makes a distance." (Shawn Phillips, musician) |
46 days ago |
notottoman you mentioned not using mineral spirits with a waterbased product. its turpintine up here to but contrary to the name waterlox is an oil based. so the stain im assuming is also oil based. that is where the problem with the benzine would come. it would take oil based right off but water being more chemical resistant i could see that working. |
46 days ago |
specifying the bases of different finishes helps alot!! |
46 days ago |
Thanks for enlightening teenagewoodworker (what a long name to type) LOL :-) -- "Even small steps makes a distance." (Shawn Phillips, musician) |
| Forum | Topics |
Woodworking Skill Share
2897 |
3909 |
255 |
941 |
220 |
Woodworking Trade & Swap
617 |
Coffee Lounge
2363 |
LumberJocks.com Site Feedback
522 |
