I have a lot of scrap wood and I'm looking ro make some boxes. I'm looking for opinions on what YOU feel is the best type of joinery for boxes. Being very indecisive and often lazy, I cannot choose which is best, miter, rabbet, dovetail or box joint. All have their advantages! And I'm beginning to feel design trumps joinery, which makes my decision harder. So what do you think and why?
A little about myself,
I mainly work with hands tools out of convenience but will fire up an old 1940's delta Milwaukee table saw from time to time and always keep a router handy. I'm looking for a repeatable joint to make boxes to give as presents.
I think the best thing to do is try a couple different starting with finger joints and miter with splinters. Do not expect your first box to be perfect as it will be a learning experience.
Cutting a box with miter corners requires a good saw set-up and execution. The first couple I made were great for the scrap bin but with each I learned something new and eventually made some good ones with splinters.
A good box requires a number of different skills and will take some time.
I've made quite a few boxes, mostly using box joints. Over the years I must have made over 30 box joint jigs and all worked, with varying results. Two years ago I bought an Incra I-Box jig, and soon after I threw all of my shop built box joint jigs in the fire. I could never make perfect fitting box joints repeatably until I started using the I-Box jig. It's easy to set up and easy to change for different sizes of box joints, usually with only one test cut before committing it to use. You should watch the U-tube video It isn't cheap, but it's well worth the investment if you plan on making a lot of boxes. Attached is a couple of photos of boxes that I made recently using the I-Box jig.
If the wood is highly figured a miter joint will give you a continuous wrapping of the pattern around the corners.
You can add a spline or you can do things like make cross splines or even very small dowel pins of contrasting wood.
Box joints are nice.
Dovetails are good but they have to be perfect on a box because they attract so much attention.
I also have the Incra jig and highly recommend it.
I wouldn't recommend box joints with plywood because its too prone to chipping out.
My favorite is box joints, followed by splined miters.
Box joints always look amazing because of the contrast. Simply beautiful.
I use the ibox too; It's a great jig.
I make a few boxes and here's my take on the joinery: non-splined miter joints give the most 'formal' look followed by splined miters. Box joints are best when there is a strong contrast between woods being joined. Traditionally, box joints were used for drawers, ammo boxes, and other utilitarian projects. I am NOT bad mouthing box joints as I really like them for some applications.
I MUST get one of those incra's. As for box joinery, just use what feels right. If it's scrap your using, play with it a little bit. Try new thing. It's a great skill builder.
To me, it depends on what I want the box to look like. Some boxes look good with dove tails, others, not so much. Really formal, to me and Andy would be mitered with no …. what we have been calling splines. My understanding is what we are calling splines are actually keys. A spline would be running down thru the miter. It's fairly easy and keeps the outside free of cross grains. I'm not too nutty about finger joint stuff. Box joint is ok, again depending on what the project is and how I want it to look. Those fancy dovetails done with the incra set up are really cool but, again…. they have to fit the project for me.
Thanks Borny for the comment on my boxes (actually 2 different boxes are shown).
I made the boxes that I posted in #6 from 1/2" Baltic Birch plywood for the sides with 1/4" top and bottom BB because I have a lot of scraps left over from a large project. These weren't intended to be "Fine Furniture", just utility boxes to hold shop tools. I frequently make boxes of this basic design mostly to hold new shop tools. I used a Freud S-BOX-8 blade set on my Unisaw with the Incra I-Box jig to make the cuts. I had no splintering problems and the cuts turned out clean and perfectly square. For the finish I applied 1 coat of BLO, followed by 1 coat of Zinser shellac, then rubbed them smooth with 0000 steel wool, before applying 2 thin coats of ZAR cherry stain. Then I applied 3 coats of Polyurethane with a light sanding between each coat to smooth the nibs.
The larger box was actually built to hold my Incra I-Box jig. Here is a photo of the inside.
The smaller box had no purpose at first, but it became a pistol box for my DIL's 9mm target pistol. The thickness of the box and the foam lined interior holds the pistol quite firmly in whatever position it is placed in when the cover is closed and latched.
I recently received a CRB7 router jig with all of the options, so I made the following box to hold it and all of the associated pieces for it. Again, the sides are 1/2" Baltic Birch and the top/bottom are 1/4" (because I have the most scraps in these sizes). I used the BLO on all of these boxes to pop the grain some in the finishing process because Baltic Birch doesn't have much visible grain and I wanted the best appearance that I could get, even though they are just "tool boxes". I designed this box to hold the main parts of the jig in layers with each higher layer fitted accordingly. I think I spent more time figuring out how to package the pieces in the box than I did building the box itself, and I'm very happy with how it turned out.
The outside of this box was finished the same way as my previously posted boxes, even to the color of the stain, so I didn't post a closed view of this one. Boxes like this made from solid wood or Baltic Birch are easy with the Incra I-Box jig, a good table saw, and the right blade.
All the different types of joints that ave been mentioned look great and work beautifully in various situations. You should definitely experiment with as many of them as possible. That being said, a perfectly clean, un-splined miter joint is at the top of my personal favorites list.
I like mitered joints too, but they are the weakest corner joints with the end grain to end grain glue-up. Almost any impact will break an end grain glued miter joint. The lock miter joint is my choice when I want strong mitered corners, but it's sometimes difficult to cut them cleanly. It depends mostly on the wood being used and also the quality of the bit. I would never use a mitered joint for the corners of a "tool box".
I've tried making a couple mitered boxes, hardest part was getting perfect 45's all the way around so there wouldn't be any gaps. Just bought a dado blade and started making a box joint jig last week. Still haven't got it dialed in perfect, considered buying the Ibox jig, is it hard to get it set up and dialed in? Also where's the best place to get hinges for the best price that aren't crap?
That's a beautiful box James!! I like the legs or corner posts a lot. Definitely adds to the design.
I have the ibox jig, haven't used it much. First time I tried it, I dialed ii in perfectly. Second time I used it, thinking I was a pro at it I failed miserably. I need to pull it back out and work on it some more. It's pretty easy to dial it in if you follow the instructions. There is a screw that helps tighten or loosen the gap inbetween the fingers. I use it on my router table, but wonder if using it on a table saw is better.
I always check ave hardware door hinges and latches. I have even found nice project hardware on clearance.
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
