Which Router Plane
Forum topic by WayneC posted 09-26-2007 01:50 AM 6944 views 0 times favorited 19 replies Add to Favorites Watch
View WayneC's profile
WayneC
13809 posts in 4338 days
09-26-2007 01:50 AM
Topic tags/keywords: handplane tool router stanley
A Stanley 271, Lie-Nielsen 271 or a Veritas Small Router Plane? Anyone have any of these and any recommendations. Here is a link for the Stanley version from Patrick's blood and gore.
http://www.supertool.com/StanleyBG/stan14.htm#num271
Here is the Lie-Nielsen Version
Lie-Nielsen Small Router Plane
And the Veritas Version
19 replies so far
Douglas Bordner
4035 posts in 4305 days
#1 posted 09-26-2007 04:00 AM
I bought a used Stanley on eBay several years ago for just exactly what LV now offers theirs for. I am not even sure if Stanley UK still produces the #271. Perhaps the slang term for this tool isn’t suited for our mixed company, but it was referred to as an Old Woman’s (or hag’s) tooth, referent to what a mouth with only one front tooth might look like.
The Lee Valley one does have the ability to be used with the iron enclosed, or turned about to be in a bull nose configuration (oh, duh, just like the ad copy describes). Not sure about the LN. The Stanley did have an optional iron that was spear-pointed with a double-bevel. I haven’t seen that feature in either of the other two. Good tool to have when cutting away around a knifed-in line for small inlay work.
The new mini-routers (Proxxon mini-plunger, and the non-plunging Stewart-MacDonald precision router base for either Foredom or Dremel tools are probably good for wasting the majority of the ground, I just don’t have the nerves of steel necessary to sneak right up to the line with power tools. Spagnuolo can pull it off, I’m just not that good!
View Thos. Angle's profile
Thos. Angle
4444 posts in 4203 days
#2 posted 09-26-2007 04:15 AM
Wayne,
I keep saying I’m going to get one of these but I don’t want the 271. It just seems too small. I’m thinking more on a 70 or 71 then make a smaller blade for it. Somewhere I read an article about making a “Grannie’s Tooth” . It looked easy and very workable.
Tom
WayneC
#3 posted 09-26-2007 04:25 AM
I have a do have a #71, but was thinking abut getting a smaller plane. In the event anyone does not know what one looks like…
Stanley #71
3810 posts in 4262 days
#4 posted 09-26-2007 04:31 AM
I have the “mother in Laws tooth ” too #271.
I believe I bought it new. <g>
#5 posted 09-26-2007 02:29 PM
Wayne:
The new ones dont have holes for the out riggers like the original has . You may have to adapt it to keep your blade parallel to the work surface on figured woods.
Cheers
WayneC
#6 posted 09-26-2007 02:32 PM
David sent me a PM. Each works well in different situations. Buy All 3. I think I like his answer best.
View Ethan Sincox's profile
Ethan Sincox
767 posts in 4415 days
#7 posted 09-26-2007 02:56 PM
Wayne,
I have a #271 that I bought from Patrick Leach, himself. I actually used it io the box I’m making right now for the bog oak inlay in the top; I decided to try using my Bosch laminate trim router (it’s too old to be called the Colt – I got this one from a retiring harpsicord maker for about $30) for the oval. I got better results from the Bosch. (On a side note, I have to say I LOVE my Stew-Mac precision Foredom router base.)
I like the #271. I had a little bit of trouble in this box, but there were several circumstances that would have made it difficult for any of the three mini routers. My inlay was too thick (so I had to route it in several passes), the oak was very grainy, and I didn’t have the work piece clamped down like I should have.
That said, I’ve been itching to try the Veritas and certainly wouldn’t mind having one. I bought be #271 before LN or LV came out with theirs; if I’d known they both had one in the works, I might have waited. The draw for me on the Veritas is the ease and precision of adjustment you’re supposed to have.
-- Ethan, http://thekiltedwoodworker.com
Douglas Bordner
#8 posted 09-26-2007 05:04 PM
Speaking of the Stew-Mac:
5260_ppstory
Caution: be prepared for a whole new category of “I wants” if you wander over for a view.
WayneC
#9 posted 09-26-2007 06:31 PM
Sweet. Was thinking I needed a Bosh Colt Kit.
Douglas Bordner
#10 posted 09-26-2007 07:38 PM
Just a point of clarification, the Stew-Mac doesn’t plunge. Just set the depth and drop it in and start routing.
That’s why that new Proxxon is looking attractive.
18618 posts in 4401 days
#11 posted 09-27-2007 12:01 AM
I had my hands on the Lee Valley one when I was at the store.. it’s a cute little thing!
-- ~ Debbie, Canada (https://www.facebook.com/DebbiePribele, Young Living Wellness )
WayneC
#12 posted 09-27-2007 03:56 AM
And you did not take it home with you? It must have been dissapointed.
I still need to find the top end for your Grandpa’s plane Deb. I will keep my eyes open…
View Dorje's profile
Dorje
1763 posts in 4238 days
#13 posted 09-27-2007 09:46 AM
Wayne -I’m with David on this…
What are you leaning toward to start with? (I’m just assuming that eventually you will have all of three!)
Although many LV tools aren’t quite as attractive as some of us would like, they sure do think about things! I like the idea of the large® base/sole for example. I’ve never used one of these, but I can imagine that there is some advantage stability wise, depending on the work of course.
#14 posted 09-27-2007 12:35 PM
Dorje… I’m sure you are going to love the Lee Valley Special that Robin talked about..
WayneC
#15 posted 09-27-2007 03:10 PM
Well, I will probably buy the LV next time I need to order something from them, and the LN next time I place an order with Craftsman Studios. The Stanley I will hold out on until I can find it for $20 or less in an antique sale for flea market some where. (assuming funding is available at the time). Guessing the LN is the most likely of the 3 to occur.
