Blank mounting question
« back to Woodturning forum
Forum topic by kmetzger posted 07-04-2015 01:03 AM 875 views 0 times favorited 3 replies Add to Favorites Watch
View kmetzger's profile
kmetzger
157 posts in 1691 days
07-04-2015 01:03 AM
I’d love to turn this candle holder but haven’t yet figured out how to chuck up the blank. It calls for mounting the blank in 7/8” recesses but the smallest pin chuck I can find is the Nova pin jaw chuck that expands into a minimum recess of one inch and would fit my only chuck, a Nova. I’ve thought of using glue blocks, first turning a tenon for the top side, drilling a one inch hole for the bottom and then working on the top. Any better ideas?
“Bore a ⅞” diameter hole about ½” deep. This hole will serve as the chucking recess for mounting the blank on the lathe and also as the hole for the candle insert. If you are confident that all the subsequent steps are going to go exactly as planned you could bore this hole ⅞” deep now, but I usually leave that until most of the turning is complete.
• Mount the blank on the lathe. I use my smallest chuck jaws (in expanded mode) to grip the piece.”
https://www.canadianwoodworking.com/plans-projects/candle-holders
-- Kim, Ajijic, Mexico, http://tinyurl.com/7w5fm25
3 replies so far
View TheDane's profile
TheDane
5348 posts in 3536 days
#1 posted 07-04-2015 02:39 AM
Kim … I have a set of ‘step jaws’ for my Nova chucks that could handle a recess that small. Otherwise, I think I would be tempted go with a jam chuck. You should be able to get a snug enough fit to keep the piece on the lathe.
View LeeMills's profile
LeeMills
489 posts in 1175 days
#2 posted 07-04-2015 03:37 AM
I think I would do a TheDane suggested.
I would drill the hole 7/8” deep to start with.
Then turn a piece of scrap 7/8” diameter. For length you need your 7/8 Plus if Pin jaws another inch, if 25mm bowl jaws about 1/2 inch. So 1-7/8 to 1-3/8 depending on your jaws.
This you can use as a jam chuck and keep tailstock support until you need to turn the recess on the bottom.
I looked at the pics and I can’t see where it makes any difference on the bottom if you use 7/8” or 1” recess.
I would go with the 1” just for ease.
This may be the same as you are saying but I am not sure.
Or, your block would need to be about 1/2” thicker.
Turn a tenon on top to fit your jaws.
Reverse and turn the bottom with a 1” recess and shape.
Reverse and turn off the tenon on top and shape.
Drill the 7/8” on the lathe as a last step.
View MrUnix's profile
MrUnix
6193 posts in 2072 days
#3 posted 07-04-2015 03:58 AM
I’d use a glue block to turn most of it, and a jam chuck to finish the bottom foot. Would make the glue block the same diameter as I wanted the base (or slightly smaller), so all that would be left to do when done is give it a slight recess. But then again, I don’t have a chuck, so I use glue blocks/threaded wood faceplates a lot!
