Table saw and workshop space
Forum topic by cjs1 posted 10-04-2009 04:20 PM 1372 views 0 times favorited 6 replies Add to Favorites Watch
View cjs1's profile
cjs1
3 posts in 3026 days
10-04-2009 04:20 PM
I iam thinking about buying either a Jet Proshop table saw or one of two Grizzly cabinet saws (GO691 or 1023SL), but I am concerned about not being able to get the cabinet saws into my basement due to their larger size. I have never owned a table saw before and don’t know if the can fit down a standard set of stairs with the way they are packaged for shipment from the manufacturer. Has anyone had experience getting a cabinet saw into their basement with a standard set of stairs?
cjs
16272 posts in 4087 days
#1 posted 10-04-2009 04:28 PM
The table will not be attached to the base, so there should be no problem (other than weight) going down a set of standard stairs.
View lew's profile
lew
11887 posts in 3624 days
#2 posted 10-04-2009 04:30 PM
I am sure, with a little extra disassemble you could get it down there. My concern would be getting projects back up the stairs.
View knotscott's profile
knotscott
7817 posts in 3244 days
#3 posted 10-04-2009 06:29 PM
The G1023, G0691, and Jet Proshop all have the same size table (27”d x ~ 40”w), and take up roughly the same amount of space. The G0691 has longer rails, but is also available as the G0690 with the same rails as the others. If you’ve got 220v, definitely get one of the industrial cabinet saws.
Take a look under the hood of each one:
Here are the guts of a G0478 hybrid that are similar to the Jet Proshop’s:
hybrid
G1023SL:
g1023sl
G0690:
G0690
View Mauritius's profile
Mauritius
96 posts in 3095 days
#4 posted 10-04-2009 07:54 PM
I agree with Lew. I have a G0478 (the hybrid, a bit smaller/lighter than the cabinets). You can take the top off, or maybe it comes separate, with the hybrid it didn’t. The cast iron wings are separate and need to be attached as part of the assembly process, and the fence comes in a totally separate box. I’m pretty sure you can break it down to manageable parts, you’ll still need a bit of muscle to get the big chunks down though.
One thing that may help is to go onto Grizzly’s website and check out the manual for the saws you’re interested in. Read through the assembly process so you know how it comes shipped, and check the maintenance section to see what all can be broken down.
View cjs1's profile
cjs1
#5 posted 10-05-2009 03:23 AM
Thanks for all the good information. I obviously need to give this more thought and some additional research. Maybe the basement isn’t the best location for a my workshop.
View Innovator's profile
Innovator
3584 posts in 3282 days
#6 posted 10-05-2009 05:42 AM
Give Grizzly a call and ask them for the sizes as shipped and they will let you know what they are.
-- Whether You Think You Can or You Think You Can't, YOU ARE RIGHT!!!
