Stair Step Treads and A Bull Nose Bit
Forum topic by Rushman posted 10-04-2009 12:40 PM 2224 views 0 times favorited 1 reply Add to Favorites Watch
View Rushman's profile
Rushman
13 posts in 3189 days
10-04-2009 12:40 PM
I am in the process of replacing 8 stair steps.( for a friend ) I ordered a bull nose bit for 1 inch material. I held it up to the steps at my house and to my surprise it does not totally fit the shape on the edge of the step. I am assuming then that after I shape the front of the tread, with the bit that I will have do some type of round over at the top and bottom of the tread to blend it in. Is this the normal way to do the steps?
Thanks
1 reply so far
27251 posts in 3730 days
#1 posted 10-05-2009 03:05 AM
I just finished up putting treads on my stairs. The treads came with a bullnose on the front but where they were cut to fit the stairway, the sides were left with a sharp edge. I used a 1/2” roundover bit to put a matching bullnose on the sides of the tread and match it with the front. The tread that I put in was 1 1/8” thick so I had a flat spot in the middle to run the bearing on when rounding over both sides of the tread. A little hand sanding blended it right in with the bullnose profile.
