Log Tenon Cutting
Forum topic by gdana2 posted 793 days ago 283 views 0 times favorited 3 replies Add to Favorites Watch
View gdana2's profile
gdana2
1 post in 793 days
793 days ago
Making a log bed for my son out of red maple logs. I have all the logs rough cut to approximate size, but trying to master the tenon and mortise. Currently using a hole saw to cut the tenon and forstner bit to cut the mortise. Need advice on how to taper the tenon so it looks better in the mortise. I have looked into the tenon cutters but the Mrs. does not want to sink a bunch money into this hobey yet. I was thinking about using the router or possibly a hand planer. Any suggestions??
View Thos. Angle's profile
Thos. Angle
4013 posts in 859 days
793 days ago
get out the draw knife and the spoke shave.
-- Thos. Angle
View Buckskin's profile
Buckskin
484 posts in 884 days
793 days ago
Tom, has the answer with the draw knife and spoke shave.
You could also carefully use a small hand axe and/or chisels and rasp.
View cabinetman's profile
cabinetman
140 posts in 1040 days
793 days ago
You could use the above mentioned tools, or what’s called a “broad hatrchet”. You could pare the tenon with regular chisels, or use a “slick” which is usually a 2” or wider paring chisel, 16” – 30” long, a timberframers favorite.
