Enduro var final coat(s) - back to back for rub out?
Forum topic by jimmy J posted 07-03-2015 11:30 AM 731 views 0 times favorited 1 reply Add to Favorites Watch
View jimmy J's profile
jimmy J
229 posts in 2344 days
07-03-2015 11:30 AM
I already put down 3 coats of enduro, sanded to 500, just laid the 4th coat. I intend to rub the finish.
question #1: ive read some people apply 2 coats relatively quickly on the final to get a thick coat, which may help prevent witness lines. Is this necessary / recommended with Enduro? Hard ro tell if enduro burns in or not – it is water borne, but crosslinking. My web search reaults conflict.
Q2: if i should do this, how long between coats?
Are witness lines a problem for semigloss?
I finish in my garage, which is about 80 degrees and 70% h.
1 reply so far
View pintodeluxe's profile
pintodeluxe
5620 posts in 2778 days
#1 posted 07-03-2015 07:13 PM
I never had very good luck brushing on a finish. I switched to spraying lacquer, and never looked back. Even the smallest projects like boxes get sprayed.
Some people like wipe-on finishes, but they require many coats vs. 2 quick coats inside of a day with sprayed finishes.
Good luck finding your best solution.
