Cabinet Scraper (Veritas Variable Burnisher)
Forum topic by USCJeff posted 2069 days ago 9259 views 0 times favorited 38 replies Add to Favorites Watch
View USCJeff's profile
USCJeff
1041 posts in 2240 days
2069 days ago
Topic tags/keywords: card scraper veritas burnisher
I have owned a cabinet scraper for a while now and it has collected dust as I couldn’t get a good burr without a burnisher. Bought a typical rod style burnisher and now I understand how handy scrapers can be. I was thumbing through my Lee Valley catalog and saw their “Vertias Variable Burnisher. It costs a little more than a nice rod style burnisher, but if it works as advertised, I want one. Anyone use one of these? I wish I saw their scraping set (4 scrapers, file, variable burnisher, holder, and jointer) for $70 before I bought some of the stuff a la carte.
-- Jeff, South Carolina
38 replies so far
34370 posts in 2572 days
#1 posted 2068 days ago
I never was impressed with mine. I’ve owned it for 6-7 years. If its the same as the one you saw.
At a finishing class I took with Jeff Jewitt he used a plain old screwdriver shank that is not plated but a just plain shaft and used it to turn the edge. It works great. I’ve also used a valve stem from a truck engine about 12” long and a 2.5” head. They are truly hard steel.
View WayneC's profile
WayneC
9596 posts in 2269 days
#2 posted 2068 days ago
I’ve got the variable burnisher as well and not too excited about it. If your looking to invest, I suggest dropping $20 on Chris Schwartz’s new handscraper video. It very clearly shows how to sharpen, burnish and use card scrapers. I got this last week and watched it over the weekend. Good video.
http://www.craftsmanstudio.com/html_p/AV18-D.htm
View Thos. Angle's profile
Thos. Angle
4400 posts in 2134 days
#3 posted 2068 days ago
New and improved seldom is. I’d suggest just learning to use the regular burnisher or any other rod that is handy.
Tom
WayneC
#4 posted 2068 days ago
An old chisel works well (round part).
View Bill's profile
Bill
2579 posts in 2333 days
#5 posted 2068 days ago
What about for filing the edge, just use a regular file? I tried a scraper once, I guess it was not burnished correctly. It just gave me a little dust was all. Not like I have seen those guys online. So I have been avoiding the scrapers for the sander instead.
View Duckarrowtypes's profile
Duckarrowtypes
67 posts in 2076 days
#6 posted 2068 days ago
I bought the variable burnisher and I like it just fine. This is the thing that I bought: http://www.leevalley.com/wood/page.aspx?c=2&p=32633&cat=1,310,41070
I’ve never tried anything else but this one has been very nice for me.
-- Custom Daguerreotypes from your images and more: www.shinyphotos.com
#7 posted 2068 days ago
Bill change the angle that you hold it to the wood. One angle you get dust, and another angle you get shavings.
The angle on the burr can change from one time to another so the angle is not always the same. Just change it and they will appear.
WayneC
#8 posted 2068 days ago
Here is a long post that describes how to sharpen a scraper. According to Chris Schwartz there are at least 15 different published methods.
http://www.inthewoodshop.org/methods/wwc07.shtml
I really do think the video I referenced above is worth the money…
View mot's profile
mot
4912 posts in 2208 days
#9 posted 2068 days ago
I use the LV burnisher for turning scrapers. As for cabinet scrapers, I use the old fashioned way and use a screwdriver shank.
USCJeff
#10 posted 2068 days ago
Good to know. Might hold off. I tried the screwdriver shaft method and it didn’t do a ton for me. Could be technique, but I read up a good but on it and think the metal might not be dense enough. The burnisher made all the difference and I get a nice burr if I hold it around 15 degrees. I normally just use the side of a sharpening stone and a drop of oil to joint the edge every 4 or 5 burnishings. I haven’t tried to joint and sharpen my concave scraper. I imagine there’s more room for error. I’ll need to soon as I’ve been using it a ton to strip spindels on 6 dining chairs. One of those times a concave spokeshave would be nice to have.
Thos. Angle
#11 posted 2068 days ago
Bill, take a piece of ply or wood and run a kerf in it about 1/2 inch deep. Find a file that fits in the groove and cut the board to length. You now have a 90 degree scraper filer. File it past square and then start burnishing until you get what you want. It will make a great finish and your fingers hot and your arms tired and your shoulders ache and your back sore.
Tom
WayneC
#12 posted 2068 days ago
Or you could buy a scraper plane Stanley #12, #80, #112, #212 or clone and not get your fingers hot.
View brunob's profile
brunob
2275 posts in 2341 days
#13 posted 2068 days ago
I also use a screwdriver as a burnisher. Works fine. Also, old handsaw blades make great scrapers.
-- Bruce from Central New York...now, if you'll pardon me, I have some sawdust to make.
View cajunpen's profile
cajunpen
11677 posts in 2238 days
#14 posted 2068 days ago
I can see that all of this hand tool talk is going to cost me even more money. Can you get too old to try new things? If so, I ain’t there yet :-)).
Wayne, you have me hooked on trying hand planes – and now scrapers too! Does the Stanley scraper planes that you referenced above take the place of the card scraper?
WayneC
#15 posted 2068 days ago
Yes, basically they provide a holder for the scraper and they range from basic #80 to complex #112/212.
Lie-Nielson #112 Scraper Plane
showing 1 through 15 of 38 replies
