Lay flat or hang to spray?
Forum topic by skatefriday posted 07-02-2015 04:52 PM 1778 views 1 time favorited 19 replies Add to Favorites Watch
View skatefriday's profile
skatefriday
418 posts in 1509 days
07-02-2015 04:52 PM
All you spray finishers out there, when spraying a bunch of
cabinet doors or drawer fronts, do you hang your parts to spray
or lay them flat on, say, saw horses?
I presume if laid flat you can’t do the opposite side until the first
is finished. If hung, does sway become a problem?
Thanks
19 replies so far
View Earlextech's profile
Earlextech
1162 posts in 2717 days
#1 posted 07-02-2015 05:01 PM
Lay flat on lazy Susan, do backs first.
View pintodeluxe's profile
pintodeluxe
5706 posts in 2840 days
#2 posted 07-02-2015 05:03 PM
I really prefer to spray parts laying horizontally when possible, as it helps the finish lay out nicely and prevents the possibility of runs in your finish.
Start by spraying the back side, then flip the parts over and set them on painters pyramids to finish the fronts. No need to wait for the finish to dry before flipping.
View Num11's profile
Num11
4 posts in 1389 days
#3 posted 07-02-2015 06:34 PM
Dumb question but how do you flip a wet cabinet door? (I’ve not figured out how to master that.)
View BurlyBob's profile
BurlyBob
5555 posts in 2292 days
#4 posted 07-02-2015 06:56 PM
Skate and Num. Thanks for asking these questions I’ve got a project I’m starting next week and was just going to muddle thru it. You’ve helped answer my questions.
View Mosquito's profile
Mosquito
9355 posts in 2319 days
#5 posted 07-02-2015 07:00 PM
The professional painter I know hangs everything he can. His reason being that dust doesn’t settle on vertical faces. Now that’s paint, and I don’t spray finish, so I don’t know if viscosity is different or something to consider here.
-- Mos - Twin Cities, MN - http://www.youtube.com/MosquitoMods - http://www.TheModsquito.com
View SirIrb's profile
SirIrb
1239 posts in 1257 days
#6 posted 07-02-2015 07:00 PM
flat. if hung the hanging method would get in the way of the finish too. I have done it and sway would happen. I like to have my stuff very stable where I can watch the light and when its moving this is hard.
View JoeinGa's profile
JoeinGa
7736 posts in 2034 days
#7 posted 07-02-2015 07:00 PM
“Very carefully” :-)
The trick is to NOT spray the edges, so you can handle it with your fingertips and flip the piece.
I dont have any fancy pyramid holders, I use simple finish nails, driven thru a piece of scrap to hold the parts up. Oh, and I usually DO wait till the backs are dry to flip and do the fronts.
View bruc101's profile
bruc101
1200 posts in 3568 days
#8 posted 07-02-2015 07:02 PM
What ever you do never rush the finish especially on a set of cabinet doors. The wall cabinets usually makes the first impressions on craftsmanship when someone walks in and sees them. You can have a master built set of cabinets and a 2 bit rush job on the finish will destroy them.
We never spray a finish on one side of anything and then flip it over immediately. If you’re using a pre cat finish you can do the flip job in 10 or 15 minutes. Even with pre cat we let a coat of finish dry at least two hours or until it sands clean before we do anything else to it.
We spray both horizontal and vertical. It’s easier to get dust particles spraying horizontal so the larger the item the more it may get sprayed vertical. For spraying vertical we have a system that holds the top and the bottom to keep it from swaying. When we spry vertical we can spray the complete project at one time.
Good luck on your project.
-- Bruce Free Plans http://plans.sawmillvalley.org
bruc101
#9 posted 07-02-2015 07:15 PM
- JoeinGa
Finish nails are painters best friend sometimes even in a professional shop lol. Always keep finish nails close by.
View NiteWalker's profile
NiteWalker
2737 posts in 2603 days
#10 posted 07-02-2015 07:35 PM
- Earlextech
This. I also use nail boards; 1/4” sheets of plywood with screws driven in so the points support the workpiece. It leaves even smaller dimples than painter’s pyramids.
View hotbyte's profile
hotbyte
991 posts in 3002 days
#11 posted 07-02-2015 07:57 PM
I remember a YouTube video where someone hung cabinet doors from the holes bored for 32mm hinges. Looked like a decent way to hang them where string/wire was out of way.
View mnguy's profile
mnguy
193 posts in 3425 days
#12 posted 07-02-2015 08:15 PM
I sprayed my kitchen cabinets, using ML Campbell water borne opaque cabinet finish (paint). I had my 2 car garage to work in, and I had to spray in small batches. I lightly drove #4 hard trim nails into the end of the doors. I sprayed on a turntable – it really helps get the edges and the relief of raised panels. I sprayed the backs, flipped them onto nail boards using the nails in the ends as handles, and sprayed the edges and then the fronts. Then I set them on nail boards, fronts up, to dry. It worked well for me.
skatefriday
#13 posted 07-02-2015 09:46 PM
Ok. Flat it is. What got me thinking about it was seeing
the hanging widgets from Rockler that go in the 35mm bore hole.
Practiced on some scrap with GF Enduro-Var this morning over
raw wood and am pretty pleased with the results. Using the
Earlex HV5500. I had 3 coats on in about 4 hours. Each coat
was dry within 30 minutes. Waited about an hour to sand with
220 and put another coat on. Manufacturer instructions say 2 hours
to recoat. I seemed to have good results coming in under 2 hours.
It is hot today though.
Which begs the next question. It takes literally seconds to spray
a couple doors. Do I really need to empty the gun and clean
in between each coat if I’m recoating every two hours?
EarlexTech, you still here? :-)
View AlaskaGuy's profile
AlaskaGuy
4211 posts in 2336 days
#14 posted 07-02-2015 10:16 PM
When I spray I leave the finish in the gun until the end of the day. I don’t clean between coats. One thing I think you should do with spraying waterborne finishes is keep a fairly damp rag handy and wipe the tip of the gun every now and then to prevent dried finish build up on the tip and cap.
I’m using a HVLP conversion gravity gun.
skatefriday
#15 posted 07-03-2015 12:53 AM
Experimenting today I found that after about an hour my gun would no longer
spray and I’d have to take the cap off and wipe off the needle and could see a
little pink film (enduro-var is pink out of the can).
