Need advice on cutting 2x12's
Forum topic by Trey posted 07-02-2015 02:38 AM 2560 views 0 times favorited 16 replies Add to Favorites Watch
View Trey's profile
Trey
84 posts in 1699 days
07-02-2015 02:38 AM
I have a project that I have to complete this weekend. I need to cut some 2×12’s, and I’m not sure which route to take. I considered making an oversized sled for my table saw. My saw sits in a 3’x8’ table, so I’d have support. I don’t have a radial arm saw or a circular saw. I’ve been looking for a used circular saw, and haven’t found anything yet. I even thought about getting a hand saw, but I’m not experienced enough with that to be confident in my cutting. Any other ideas?
I know this probably sounds like basic knowledge to all of you. I’ve never cut lumber this size. I’m not sure how much my table saw would enjoy it.
16 replies so far
View DIYaholic's profile
DIYaholic
19618 posts in 2669 days
#1 posted 07-02-2015 02:47 AM
Are these rip cuts…. cross cuts…. beveled cuts…. miter cuts…. or a combination?
View Trey's profile
Trey
#2 posted 07-02-2015 02:48 AM
Sorry, I should have said that.
Cross cuts.
View Tugboater78's profile
Tugboater78
2743 posts in 2186 days
#3 posted 07-02-2015 02:54 AM
I would go buy a cheap $30 skil saw. Edit: triangle shaped carpenters square use as a “fence”. mark where cut needs to be, line up blade, slide square up to baseplate hold it steady and keep baseplate against square.
Or even cheaper hand saw and a cheap square, mark a line all around the board, start at one corner and stay on my line, once you get 2 corners mated with the kerf and a steady arm, in about a minute should have a straight cut.
All assuming this is a crosscut
Rip or bevel isnt much harder, though i wouldnt wanna rip with a handsaw.
-- "....put that handsaw to work and make it earn its keep. - summerfi" <==< JuStiN >==>=->
View Trey's profile
Trey
#4 posted 07-02-2015 03:08 AM
- Tugboater78
I’m thinking a circular saw is really my best option. Homedepot has one for $40. And its green.
Tugboater78
#5 posted 07-02-2015 03:15 AM
- Tugboater78
I m thinking a circular saw is really my best option. Homedepot has one for $40. And its green.
- Trey
The cheap ones work great if taken care of and/or dont get used much. I still have my Skil brand one i bought years ago, it doesnt cut accurately anymore. Brother was helping my cut some boards and dropped it on carports concrete floor, bent the baseplate. It now has a stone cutting blade in it and i use it for cutting landscape block.
View waho6o9's profile
waho6o9
8187 posts in 2571 days
#6 posted 07-02-2015 03:21 AM
Maybe make a DIY track saw, clamp everything down
and cross cut all of them at once. Or maybe a couple of cuts.
View Trey's profile
Trey
#7 posted 07-02-2015 03:26 AM
- waho6o9
You mean I won’t have to cut plywood on my table saw anymore!? I’m definitely buying one now.
View MT_Stringer's profile
MT_Stringer
3168 posts in 3225 days
#8 posted 07-02-2015 03:28 AM
Kreg makes a circular saw/jig saw cross cut helper that works well. Adjust it, the first cut will cut the plastic tab. That is where you line up you cut mark each time.
http://www.ustoolandfastener.com/kreg-square-cut-saw-cutting-guide-kma2600/?gclid=Cj0KEQjwn86sBRDroPiR0LrSzNYBEiQAzOaSYH3BzHy4bpOhnx5m-RAmHqWhiepOHXkuKix-qrpnGpsaAgAb8P8HAQ
I have one and use it often.
Here’s a video.
https://www.youtube.com/watch?v=g2oTiIWUwPo
View Trey's profile
Trey
#9 posted 07-02-2015 03:30 AM
- MT_Stringer
Does this have an advantage over using a framing square?
MT_Stringer
#10 posted 07-02-2015 03:31 AM
Watch the video.
Tugboater78
#11 posted 07-02-2015 03:34 AM
https://m.youtube.com/watch?v=n-1XKctLrAU
Well worth making if you plan on cutting any plywood in the future, especially
I made a diy version of this
And is great for cutting lumber, sorry no pics of mine atm, not able to get out to shop, carpenters square basically does same if you do as i mentioned above, or measure/mark a line compensating for the blade-baseplate difference.
Edit: mike beat me to the punch, i had kregs version for a while, but i wore it out.
Tugboater78
#12 posted 07-02-2015 03:42 AM
- MT_Stringer
- Trey
The skinny tab you can put on your cutline after adjusted for your saw and guaranteed to have a square cut if held steady
View Trey's profile
Trey
#13 posted 07-02-2015 03:47 AM
I went ahead and ordered the Kreg guide. I can use it for my jig saw too. I’ll pick up a cheap saw tomorrow, and get to it. Thanks for the advice!
View bandit571's profile
bandit571
19962 posts in 2677 days
#14 posted 07-02-2015 04:36 AM
While you are out there…pick up a large speed square. In the rack where they’ll have these squares, they will be a couple framing squares. Use a framing square to check the squareness of the speedsquare, keep checking til you find a good one.
Also, do NOT rely of that angle guide on the saw. Run the blade out to full depth of cut, and check the sole to blade for square. You’d be surprised at how far off some of those angle settings are. Set the sole to square with the blade, and lock it down tight.
Also, there will be a notch or line on the sole of that saw, check to see just how it lines up with the blade in the saw. That way you’ll know where you will be cutting a line at. Sometimes, that marker isn’t really close. Straight edge alongside the blade, on either side, just so it also runs out past the front of the sole. Note where it lines up with the notch.
View Trey's profile
Trey
#15 posted 07-04-2015 03:15 AM
Well, I bought a circular saw, freud blade, and the Kreg guide. Very happy. I had to build this bench made out of 2×12s and others, and it was super easy! It’s not finished yet.
Thanks everyone!
