Show & Tell: Flattening a glued up panel...
« back to Hand Tools forum
Forum topic by bandit571 posted 07-01-2015 06:15 PM 1033 views 0 times favorited 9 replies Add to Favorites Watch
View bandit571's profile
bandit571
19741 posts in 2650 days
07-01-2015 06:15 PM
Topic tags/keywords: tip pine plane milling
With just a few handplanes. Only electric needed is for the overhead lights…
The Panel. Just four pine boards. Resawn from a 4×4, and a little uneven. Clamped down to the bench
First plane to see the panel. About 14” long, with a cambered edge to the iron. Somewhere around a 8-9” radius, might have resharpened it once in the last year or so
This is what I look for, thick curls. I go almost straight across the grain, other than a diagonal at a big knot.
When I start to get these shavings all the way across, it means I am almost flat, time to switch gear
A 18” long Fore plane/try plane. I now go at a diagonal to the grain, looking to level out the scoop marks. Starting to get a decent long shaving across the panel….on to the next plane
A Smooth plane? not exactly, 14” long smooth planecleaning up the diagonal marks from the longer plane. Then a shorter smooth plane can clean up as needed…
Panel is now flat, and smooth enough not to needed sandpaper. Doesn’t take all that long, either.
9 replies so far
View DIYaholic's profile
DIYaholic
19597 posts in 2642 days
#1 posted 07-01-2015 06:55 PM
Nicely done.
Looks like it COULD be fun….
But I’ll stick with my electron killing thickness planer!!!
View lightcs1776's profile
lightcs1776
4200 posts in 1621 days
#2 posted 07-01-2015 07:13 PM
Nice! I love using my planer, but it certainly isn’t as quiet as doing it with hand planes.
-- Chris ** If there must be trouble, let it be in my day, that my child may have peace. — Tom Paine **
View Handtooler's profile
Handtooler
1544 posts in 2099 days
#3 posted 07-01-2015 08:04 PM
Thanks for the pictures and excellent blog. Quite professionally flattened and ready for the glue up, huh? Or do you go to the jointer for edge truing?
-- Russell Pitner Hixson, TN 37343 bassboy40@outlook.com
bandit571
#4 posted 07-01-2015 08:15 PM
Edge truing up is by the jointer…planes
This one is a No.6c. Depending on the length, I will use either a #5 jack plane up to the 24” long Stanley #31. That one is in my avatar,BTW
View WoodNSawdust's profile
WoodNSawdust
1417 posts in 1143 days
#5 posted 07-01-2015 08:16 PM
Thanks for the instructions.
View Mattyboy's profile
Mattyboy
50 posts in 1045 days
#6 posted 07-01-2015 08:30 PM
Nicely done, Bandit. There’s a lot to be said for doing this by hand – little noise, good exercise, building skill, no electrons, great feeling of accomplishment. Probably more people would flatten panels this way if they realized that with just a bit (OK, a fair amount) of practice and sharp tools it is not as tough as it sounds.
-- Matt, Northern CA
View CFrye's profile
CFrye
10131 posts in 1806 days
#7 posted 07-01-2015 08:54 PM
Nicely done, Bandit! Was the flattening done before or after edge jointing and glue up?
-- God bless, Candy
bandit571
#8 posted 07-01-2015 09:28 PM
Panel is shown right after it came out of the clamps. Edge jointing with a plane right before they were glued up.
Not quite the same as Mr. Schwarz would do things…...things seem to work better for me this way…
Took maybe a quarter of an hour. Long time ago, it was tablesaw resawn pallet Oak, vs a Stanley Blue No.110 block plane. Took a bit longer back then….
Boards were resawn, edges jointed, then glued up into the panel. Then the fun can begin about a day or so after the glue up. had other things going on. Finally got around to plane work on this small table top…
View hotbyte's profile
hotbyte
991 posts in 2942 days
#9 posted 07-01-2015 10:16 PM
Nice post. I’m trying to get more into hand tools. With home construction projects lately it’s a slow curve.
