48" edge sander - is there such a thing?
Forum topic by Puzzleman posted 07-01-2015 04:42 PM 1140 views 0 times favorited 5 replies Add to Favorites Watch
View Puzzleman's profile
Puzzleman
417 posts in 2971 days
07-01-2015 04:42 PM
Topic tags/keywords: sander 48 6 edge sanders
I have several edge sanders but they take a 80” belt. I need one that takes a 48” belt for small parts that I am working on. I can find belt sanders that take a 6×48 belt but they do not go horizontally.
Anyone know of one out there?
Or has anyone taken one of the 6×48 sanders and turned is sideways? If so, problems?
If not, what are your ideas??
Thanks, Jim
-- Jim Beachler, Chief Puzzler, http://www.hollowwoodworks.com
5 replies so far
View rick1955's profile
rick1955
264 posts in 1458 days
#1 posted 07-04-2015 01:24 AM
http://www.grizzly.com/products/G1072
You guys need learn how to use search engines. When I first got on Web 22 years ago I asked a question and the responses were so stupid. I just learned how to go directly to the answer. I had the answer to your question in 20 seconds.
Oops… Discontinued then just tip a sander on its side.
-- Working smarter with less tools is a true crafts person...
Puzzleman
#2 posted 07-04-2015 01:32 PM
Yes, I saw that one as well but I realized it was discontinued before I opened my mouth to talk about it.
Tipping a sander on it’s side is not a good option when you are going to be doing production work on it. I would also need to build a table that would be secure to the sander to ensure that the edge is a 90.
Not as easy as you think it would be.
Will probably get a 80 inch edge sander and figure out how to shoe horn it into the shop.
View AZWoody's profile
AZWoody
1346 posts in 1251 days
#3 posted 07-04-2015 01:44 PM
Grizzly has the 80 inch in a floor model and benchtop. When I was at their showroom I saw both of them and the benchtop is pretty compact so may fit in your shop.
I have the floor model and it has done a good job so far.
View Crank50's profile
Crank50
173 posts in 1603 days
#4 posted 07-04-2015 03:59 PM
Is the Ridgid belt/spindle sander too short or narrow for your application? It gets very good reviews.
On the other hand, an 80 inch belt is going to be only about 34” long when mounted between two spindles. That doesn’t seem like a really huge machine.
AZWoody
#5 posted 07-04-2015 04:07 PM
On the other hand, an 80 inch belt is going to be only about 34” long when mounted between two spindles. That doesn t seem like a really huge machine.
- Crank50
Good point on the Rigid, I have that as well and it’s awesome for working on smaller pieces.
