spoke shave across the grain
Forum topic by Eric posted 07-01-2015 12:51 PM 899 views 0 times favorited 6 replies Add to Favorites Watch
View Eric's profile
Eric
221 posts in 2512 days
07-01-2015 12:51 PM
I need to plane a concave curve. Before I spend my &, can a round bottom spoke shave be used across the grain?
OR
Does anyone have a cost-effective lead on a round-blade plane that would let me go with the grain? I working the underside, concave curve of a sleigh bed head/foot board.
-- Eric
View Bill White's profile
Bill White
4932 posts in 3961 days
#1 posted 07-01-2015 01:09 PM
Angle the spoke shave just like you’d angle a bench plane for cross grain cutting. This allows the blade to “shear” the wood fibers.
To answer your question, a convex bottom spoke shave will work well on concave surfaces.
Bill
-- bill@magraphics.us
View jdh122's profile
jdh122
1013 posts in 2818 days
#2 posted 07-01-2015 01:18 PM
Yes, it will work. Make sure it’s sharp, obviously. You can angle it like Bill mentions, although if the curve is too tight this will not really work, since it kind of reduces the curvature of the sole.
-- Jeremy, in the Acadian forests
View shipwright's profile
shipwright
7980 posts in 2798 days
#3 posted 07-01-2015 02:35 PM
You might try a custom shaped scraper as well.
View Ripthorn's profile
Ripthorn
1458 posts in 2985 days
#4 posted 07-01-2015 02:49 PM
I’m a little confused at you stating across the grain and then mention a sleigh bed part. Can you not go with the grain with a spokeshave? A custom scraper will work nicely and would be a lot cheaper than either of the other tools. If you can go with the grain, a sharp scraper will shape and finish nicely.
View Eric's profile
Eric
#5 posted 07-01-2015 03:44 PM
I’ve pieced the top curved unit together at 20 degree angles. I’m hoping to “plane” that curved joint smooth on the concave side after glue-up.
-- Eric
View rwe2156's profile
rwe2156
2926 posts in 1481 days
#6 posted 07-02-2015 11:11 AM
I’ve had problems with chattering on end grain even with a flat spokeshave, but its possible depending on the wood.
Try it and if that happens then a scraper is the way to go IMO.
